Setting Up The Muso
Posted by: Bazza on 19 July 2018
I recently bought the Muso and am currently awaiting delivery of an Oppo UDP-203 and Samsung 55" QLED TV which is the model line with the near invisible cable.
This TV has a one connect box which you plug other devices into rather than directly to the TV.
I just wondered how best to connect everything to the Muso to get the best out of it and the Oppo.
Any suggestions / help greatly appreciated.
Posted on: 19 July 2018 by GregWPGibbs
For flexibility, you could connect the Oppo to the QLED  One Connect box via HDMI and then connect the One Connect box to the Mu-so via optical cable - this would allow any source connected to the One Connect to play through the Mu-so.
If however you want the best audio from the Oppo, I’d connect it directly to the Mu-so (via optical).
Also, remember that the Mu-so is stereo only, so whatever is connected to it needs to be set to PCM sound.
Posted on: 20 July 2018 by Bazza
Thanks, Greg. Very helpful.
If I do the latter, connect the Oppo direct to Mu-So optical, will other devices, such as Sky Q, Apple TV, that I connect to the One Connect box not drive sound via the Mu-So?
