Vinyl pops and crackles
Posted by: dolorem on 22 July 2018
hi all
firstl loving these forums and have to admit this is the first on line community I’ve truely engaged with.
I’m doing some research on vinyl in the hope of writing a guide to how to use it properly. I find it fascinating at a very technical level that so much information can be pulled out of a groove in a piece of plastic. I’m an engineer and as such so much just doesn’t add up particularly the difference between original pressings and re issues. Early original pressings just sound better have more attack presence and imaging than later reissues. Even when reissued by bands that know production. Eg The great gig in the sky by pink Floyd. Why why why. Are reissue records made differently, surely they have the original tape just cut a new master and press a new record.
Now the main question I have. Im interested in vinyl restoration. One is it possible and two how. A guy in a yellow suit on YouTube plays a record heavily worn. He then washes it it soapy water- not a fan by the way- it has reduced crackle and pop. Then he wipes it with a petrol based lubricant-WD40 ouch hello desolved plastic wrecked stylus etc etc . However. He demonstrates significant noise reduction. So I tried it on a very damaged record and old spare stylus. It worked. So I started thinking what are the mechanics.
i then started on the chemistry a lubricant that leaves no deposit behind and would have no detrimental effect on vinyl and no detrimental effect on stylus construction
silicon and water based lubricant both work. Hello sex shop. I won’t tell you about the raised eye brow I got when I spoke to the very helpful women at Max Black in Sydney. Luckily she has lots of old records and got right into it we both laughed and exchanged numbers.
Thoughts
Posted on: 22 July 2018 by Skip
I use the Disc Doctor products on a VPI 17. This works very well. I also use a Superline Supercap phono stage. Noise is greatly reduced with the Superline. Don't ask me why.
Posted on: 22 July 2018 by Bob the Builder
I just bought a Miles Davis original six eye mono that looked like it had been driven over by a car. A Very Good plus copy would set you back £150 or more mine was less than £10 but after a thorough hand wash working the cleaning fluid into a lather and then a very good clean on the vacuum record cleaning machine it now sounds beautiful it still looks a bit rough but plays fine apart from a few pops and crackles which are ok.
Posted on: 22 July 2018 by Richard Dane
Back in the '70s there was a fad for playing records wet, which resulted in much reduced noise. Unfortunately once you played a record wet, it always had to be played wet - if then subsequently played dry it sounded terrible. Heaven knows what long term damage was being done though - not just to the LPs but to the stylus and cartridge as well...
Posted on: 23 July 2018 by joerand
Back in the late-70s I was Xmas gifted a can of silicone spray and cloth applicator intended to "clean" LPs. Definitely reduced pops and crackles, but once over that I realized it also dulled the dynamics. Fortunately I only used it on a dozen or so LPs. Even more fortunate, when I bought a RCM some three decades later, I found it was able to clean the crud from these siliconized LPs and restore them to decent SQ.
I never did LAST (nor would I), but the few treated LPs I've bought from the used bin (LAST sticker intact) sound excellent. For me the lone exception to the "never treat your records" rule. Might have [@mention:1566878603910888] 's ears ringing.
Posted on: 23 July 2018 by Peder
Since I bought my first LP12 in 1983,I have never thought about whether I have pops and crackles.
Have actually honestly never heard it,the musical message dominates so large.
On the advice of the Swedish Linn-distributor,I also ended in 1983 to use a disc brush.
He said that you just brushed down the dust in the disc tracks,..instead let the needle catch the dust.
The only thing I've used is Linn's "Green Paper" to clean the needle,as well as the well-known thing that vibrates (forgot the name),to also clean the needle.
/Peder ????
Posted on: 23 July 2018 by Beachcomber
dolorem posted:
Thoughts
Well, I think it sounds like you're in with a chance there.
Posted on: 23 July 2018 by Innocent Bystander
Such was the increase in frying eggs and bacon sound on my most played LPs (many 100s of plays), despite scrupulous care with arm/cartridge setup, cleaning and avoiding touching etc, that I attributed it to wear, and the increasing noise was a factor in my eventual move completely away from vinyl. It seems from what I have learnt since that increaing ingrained dust may have been a significant factor, as I did not have a liquid record cleaner, and others claim wear is inaudible (though I have no idea how many plays their records get, nor what level of noise to them is simply ignored).
A good cleaner certainly makes sense - however I have never heard a completely silent LP, always having at least some feint sound in quiet passages, and often having the odd more significant ‘click’ or whatever.
Posted on: 23 July 2018 by AndyP19
This seems to be the the current fad, although does remind me somewhat of the weird and wonderful days of 1980's DIY Hi-Fi.
Lots of youtube videos on this 'method' of cleaning vinyl which appear to work if done correctly.
http://digg.com/video/clean-dirty-vinyl-wood-glue
Posted on: 23 July 2018 by Pev
I only have a modest Disco Antistat cleaner but I was amazed at how much it reduced the noise on the oldest of my records. I have a few from over 50 years ago which had really suffered during my teenage years but they are now very listenable if not perfect, in spite of horrendous looking visible scratches.
My theory is that the old sapphire styli in the Dansette BSR and Garrard autochangers I used in those days never got near the part of the groove that my VdH tipped Troika nestles in these days.
???? PEV,....Whaoo Troika,...the sexiest pick-up that has been produced.
Especially if you have a black tonarm,black against red ????.
Here we are several who use retipped Troika's.
/Peder ????
Posted on: 23 July 2018 by TK421
Pops and Crackles, I just wondered if any forum members have come across this piece of kit....
Sweet Vinyl SC1 it's not a cleaning machine.
I believe you plumb it in between your phono stage and preamp.
Audio T have a 2 part blog on it.
Posted on: 23 July 2018 by james n
The SC1 was reviewed in this months HFN. Certainly a much better modern equivalent of the Garrard Music Recovery (!) module
IME the prominence of pops and crackles also has to do with the cart. The Rega Exact for example, can tend to reduce these vinyl noises, albeit at some expense to speed and dynamics. My own preferred cart, a Grace F9E with Soundsmith stylus is a bit noisier by comparison, but the advantages of superior bass speed, transient punch, and top-end shimmer far outweigh softening of an occasional pop.
Posted on: 24 July 2018 by Hook
joerand posted:
Eh?
I do think LAST is good, but try not to proselytise. I know it can't make a bad record sound good, but it does seem to do a good job of keeping good records sounding, er...good.
Here's a picture LAST has used for many years to make their case.
james n posted:
Fremer had a surprisingly positive review of the SC1 on AnalogPlanet back in April.
Posted on: 24 July 2018 by nickpeacock
Slightly off topic, but unavoidable.
“Somebody was trying to tell me that CDs
are better than vinyl because they don't have any surface noise.
I said, 'Listen, mate, life has surface noise."
John Peel, of course. RIP.
Posted on: 24 July 2018 by Alley Cat
TK421 posted:
Interesting hardware option, then of course there are software options, I wonder if anyone has used this that I purchased some years ago before I got fed up trying to digitise LPs via an Apogee ADC - just need something like this software to run in real time when playing LPs to a digitiser and send back to analogue again!
Posted on: 26 July 2018 by Yetizone
Dolorem,
Re vinyl cleaning - It would be worth checking out two products - “Record Revirginizer” and “Winyl Record Cleaner”. Based on the PVA / Wood Glue method of adhesive deep clean peel - but purposely designed for the task of cleaning records, so no (allegedly) long term hidden effects.
I’m in the middle of experimenting with both products (currently have vinyl drying) on non precious records with varying degrees of contamination, a couple almost unlistenable due to surface noise. Without getting too carried away, lets just say the results I’ve experienced so far are deeply impressive.
I intend to do full write up with pix in the next few days (if ok with mods).
