BBC podcasts using uniti
Posted by: balma01 on 26 July 2018
Using the naim app conected to an uniti atom I'm looking for BBC RADIO3 Late Juctions podcasts.
I select "Europe/UK/BBC Radio3/Late juctions"  but it's empty.
Why?
I do not think it's a geo restriction limit bcause using the BBC app, I can play the poscasts.
Thanks in advance
Posted on: 26 July 2018 by ChrisSU
There has always been a wider range of podcasts available on the iPlayer app than you find on the Naim app. Probably worth pointing out your findings to Naim support, as I'm not sure it's meant to be this way, and it may be that they can push vTuner into improving things if people point out any shortcomings.
Meanwhile, I would consider using the iPlayer radio app into the Uniti. If it's one of the new Units, you can easily do it with Airplay. For the old Unitis, you would either need to connect an iOS device into the USB port, or add an Airport Express and use Airplay.
Posted on: 27 July 2018 by garyi
I am not in front of mine but I thought you could pull up say radio 3 then click down to reveal stuff beneath it? I’ll have to check when I get home
Posted on: 27 July 2018 by balma01
Thanks, let me know if you find something...
