NAC202 - headphone amp connectivity
Posted by: BenW on 06 August 2018
I'm looking at picking up a used 202, so need to clarify this position.
The question is on where to take a feed for the headphone amp. I already have a nice class A headphone amp, which has its own volume control, so can work with either a fixed or variable output. Am I right in thinking the AV output is a permanent fixed output? While it would be 'nice' to use the 202 volume control it isn't essential.
What do you do? (or is there a normal recommendation for this requirement?!)
Thanks!
