Should I arrange my two power strips (extension blocks) for Digital & Analog OR for Linear & SMPS
Posted by: vintageaxeman on 08 August 2018
I have read quite a few posts on a number of forums where folk reckon it is better to split their power requirements.
The system comprises a number of Naim items, and some from other manufacturers.
I also have an Ikea remote controlled (dimmable) LED light strip & power supply.
I use TWO industrial quality extension blocks (no LED, no filtration, no switches) to feed everything.
The two extension blocks are fed from the same double wall socket, which is part of the downstairs ring main.
At this point in time, creating a separate circuit for the hifi system is not really an option for me.
So my question is this:
IF it is better to 'split' my various items between two extension blocks, is it better to arrange them as:
1. Power supplies for digital devices fed from one block, & power supplies for analogue devices fed from the other?
or
2. Linear power supplies fed from one block, and switched mode power supplies, wall warts, LED supply fed from the other block?
Of course some of my equipment (Naim CD player for example) has both digital AND analog circuits inside....so where does THIS plug in for best option.
As regards experimentation, I have 9 items to contend with, so the permutations for positioning are actually 8x7x6x5x4x3x2x1=40,320 possible combinations, so I am hoping that your advice will give me a head start!
I look forward to some recommendations from you guys!
