Size of disc space remaining?
Posted by: Icedragon05 on 11 August 2018
Apologies Newbie with Core, and I'm assuming there must be a way.... does anyone know how to find out how much internal space is remaining on the disc? I've tried browsing network but properties returns 0 bytes to both the downloads and music folders....
I can't find any settings / info on the app or support pages either
Core with 4tb Seagate Win 10 PC
Posted on: 11 August 2018 by David Hendon
It's easy! You go to the Core part of the Naim app, tap the cog or gear wheel, then select "Manage Music Stores" then "View Store" and all will be revealed to you on the the bottom line.
best
Posted on: 11 August 2018 by Icedragon05
Nice one, easy when u know how
Posted on: 11 August 2018 by Pcd
Go into the App select Core go to settings then select manage music in manage music look at configure music stores select view store that should bring up the internal hard drive  showing the capacity and was is available.
