Internet radio keeps freezing
Posted by: bob60 on 12 August 2018
Hi everyone
I have been using the internet radio on my unitilite for the past two days and it keeps stopping. It is ok for a couple of minutes then it freezes for a few seconds before starting playing against.
My internet connection is excellent so not sure what the problem is.
Anyone else having this problem?
Posted on: 12 August 2018 by Guinnless
All stations? WiFi?  Have you rebooted your router?
I had BBC R6 320khz on all yesterday morning on the Qb with no issues.
Posted on: 12 August 2018 by bob60
Hi
Yes it is on all stations. I haven't rebooted my router but will give that a try right now
I rebooted my router but it has made no difference, the radio still cuts out everything few minutes for a few seconds. I have tried about eight of my preset stations and it happens with them all. First time I have had this problem.
OK at least we should have eliminated the router. Are you on wifi or wired ?
Posted on: 12 August 2018 by Mike1951
I used to get this on my ND5XS but fixed it with the firmware update.
Would this apply to your Uniti?
