adding amp to Atom
Posted by: longmanjon on 16 August 2018
When adding an external amp like a NAP200 to a uniti Atom, is there anything in the settings which needs to be disabled. If I remember right on the UQ you used to have to disable to internal amp section I think?
Posted on: 16 August 2018 by ChrisSU
I’m pretty sure the Atom will detect the connection of an external amp automatically, unlike its predecessor. In the days of good old fashioned manuals, you cauld have looked up the answer, but with the Atom you don’t have this option.
Posted on: 16 August 2018 by Gazza
Certainly on my Nova, just plug in the other amp in the Din socket and it’s done. I think the atom is rca sockets only but still should not need a change of settings.
Posted on: 16 August 2018 by longmanjon
Many thanks for the answers, I did wonder if it is automatic. Hopefully it switches of the power section to save power and heat.
yes the manuals now seem a bit lighter
I have a funny feeling the power amp is not shut down when another amp takes over......hope I am wrong on this
Posted on: 16 August 2018 by james n
Is there a setting in the menu to disable the internal power amp ?
Posted on: 16 August 2018 by hifi-dog
If not you could bi amp? With atom for the tweeters...
Posted on: 16 August 2018 by Alley Cat
james n posted:
No
Posted on: 17 August 2018 by audio1946
others still supply a paper manual which is far better than digital. MEAN penny pinching from naim
