Isolation Plinth for Uniti Star
Posted by: GregWPGibbs on 22 August 2018
My Uniti Star currently sits on a fairly solid, oak cabinet and sounds pretty good playing through Kudos C20s. As the Wife has ruled out replacing the cabinet with a dedicated rack on aesthetic grounds and I feel a Fraim would be a bit over the top with my modest setup, I’ve been looking at isolation platforms to sit betwixt Uniti and cabinet.
I’ve tried a cheap-ish acrylic / sorbothane solution but found that (1) it had little or no effect sonically and (2) due to the uneven weight distribution of the Uniti, it did not sit level (requiring additional support on the right).
I’ve recently spotted a possible solution on eBay from a guy who sells a range of “Naim Fraim styled” (his words not mine) racks. He has recently introduced a spiked wooden plinth with a glass shelf above it siting on 3 ball bearings.
Although they guy doesn’t accept returns, they are quite reasonably priced, so I’m tempted to give it a punt. But, before I do, I wonder if anyone has any experience of this sort of thing and what (if any difference) it is likely to make to the sound.
