Superline/HCDR vs. Superline/SC - Dr'ing the SC??
Posted by: Andib on 25 August 2018
Hello everybody,
actually I'm in the great situation to own both options and I prefer the former one. Does it be worthwhile to do the SC-Dr-upgrade? Probably yes but it's irritating that the SC does not make the game without DR. Or not? Before selling it I'm thinking about servicing and dr'ing it (servicing also the SL). And because that is not cheap I hope to get your advises.. Thank you!
SL 2008, SC (non DR) 2010, HCDR (2014)
AndiB
Posted on: 25 August 2018 by lyndon
ANOIB
supercap over a Hicap DR every time and if you get the black series the DR option is always available which will bring more realism and refinement, having gone from supercap to DR on both superline and snaxo it’s a very worthwhile upgrade
lyndon
Posted on: 25 August 2018 by FangfossFlyer
In my experience I found the Superline with a Supercap to be a really significant upgrade to that of a Hicap.
I then had my Supercap DR’d and I was even more pleased with the results with my Superline. So much so that I believe the Superline still has hidden potential if only Naim has the inclining and investment to pursue it!
Richard
Posted on: 25 August 2018 by Adam Zielinski
Another vote for Supercap DR on a Superline.
I love the above so much, that my 282 runs with a HiCapDr
I would have to agree with Adam
source first principle, the phono stage being more important than the pre amp as it is dealing with a more delicate signal
which is why I’m now looking to move up from a superline given the relative price imbalance between a 552DR and a superline S/cap DR
lyndon
lyndon posted:
lyndon
Which phonostage are you considering now?
Adam
im considering the Tom Evans Master Groove SR
but also looking at alternatives, the bottom line is whatever I get must work well with the Naim amps
lyndon
Posted on: 25 August 2018 by Andib
Thank you for answering! I am a bit surprised that my SC does not convince.. Could it only be the age and the non-dr status?
Andib posted:
How is it connected? With the special Burndy?
Yes, with the snaxo/S-line-Burndy. But pre-loved and I'm not sure that that is not the problem..
Posted on: 25 August 2018 by Chris Dolan
Although I am not a Superline user, I have to say that I was very impressed by what the Supercap DR achieved - over and above a non-DR Supercap.
Posted on: 25 August 2018 by Foot tapper
I tried a Superline with my serviced, olive supercap and it sounded very good when listened to in isolation.
Then I plugged in a supercap DR.
It was laugh out loud better.  The audition stopped at that point because I just wanted to hear how good album after album could sound with the Superline/SCDR.  That's always a god sign that something is working brilliantly.
If you want a world class phono stage, then a SL/SCDR is a great benchmark.  Last time I switched phono stages, I tried many "world beating, miles better than anything by Naim or Linn, 5 star rated" phono stages.  It's a minefield out there.
At this level, it seems that you need to audition the combination of cartridge & phono stage as a pair, as even great stages don't bring out the best of every phono stage.  For example, The Trilogy 907 works beautifully with Kiseki cartridges but isn't quite right with my Dynavector, others swear by Ortofon + Whest (not my taste though).
Hope this helps, FT
Posted on: 26 August 2018 by yeti42
Perhaps the Burndy needs a massage.
How does it sound if you swap the DR from the 252 to the SL, do you still prefer the hicap?
Posted on: 26 August 2018 by Andib
Then the SL sounds better but I still prefer the HCDR. I think the DR-Symbiosis is here the effect. So dr‘ing the SC makes sense. I will try it when servicing the Superline. Thank you all for helping!
AndiB
Posted on: 31 August 2018 by Rockingdoc
Another vote for the Superline with DR Supercap. It makes no scientific sense (that I can see), but the RFI sensitivity of my Superline  seemed much improved when I had the Supercap upgraded (swapped actually) to a DR version.
The Superline is however, hugely sensitive to the correct cartridge loading, and in my experience this makes as much difference as the power supply. It is really just a measure of the fantastic resolution possible from the Superline.
Posted on: 31 August 2018 by yeti42
I seem to remember the SL versions of the Lyras were prefered with the standard superline. Kuma of this parish was involved in a lot of them if you want to search, add Kleos SL to narrow it down perhaps.
Posted on: 01 September 2018 by Richard Dane
Yes, IIRC the SL Lyras came about through a request from Chris Koster of NANA for a lower output cartridge to best match the Naim Prefix and then subsequent Superline.
For Standard Lyras the slightly lower gain Superline "E" is likely the better choice.
Posted on: 01 September 2018 by Chris Dolan
The Lyra Kleos SL is a lovely cartridge - using an Aro I prefer it to the Linn Kandid. Couple that with a Superline / Supercap DR and it would be bliss
Posted on: 02 September 2018 by yeti42
I mentioned it because the OP lists a standard Lyra Delos in his profile.
