I've had some old gear in storage and after a huge struggle moving boxes I finally located the Nac 72 and some Hi-Caps.
Where however have the SNAIC's gone.
I found in another box of cables a zip-locked back with a 5 pin to 5 pin DIN lead labelled NA-22 - could this be a general DIN interconnect, might it have come with an old Naim CD player I am yet to find?
Presumably not interchangeable with a SNAIC?
Also, can someone confirm that I use a 5 pin SNAIC to the Hi-Cap, then the 4 pin DIN to XLR to the 250. Naturally my manuals are hiding somewhere else in storage too!
Oddly many of the DIN sockets on the 72 and Hi-Caps have a white dusty film on the black parts and possibly some white gritty stuff on one - dirt/dust/mold? Don't remember them being like that before, though some look pristine so maybe the connectors go like this with age? Isopropyl alcohol ok to clean them with?
Guess they could all do with a service anyway.....
Posted on: 02 September 2018 by Alley Cat
Even more baffled now.
I knew I had box of leads in the other room:
5 pin to 5 pin DIN - simply has a small 'c' on it (grey)
5 pin to 5 pin DIN - NA-20 (grey)
5 pin to 5 pin DIN - NA 34 (black)
Could some kind soul enlighten me as my organisational skills have deserted me in later life!
(The next challenge will be several dozen 'wall wart' PSU's for various gadgets/hard drives - a disaster waiting to happen - I fired an old Seagate desktop drive enclosure last year, though I still think it was the correct PSU adapter).
Alley Cat posted:
Oops...edit:
5 pin to 5 pin DIN - simply has a small 'c' on it (grey cable, white label) - perhaps it's a small 'u' not a 'c' ?
5 pin to 5 pin DIN - NA-20 (grey cable, white cable)
4 pin to 4 pin DIN - NA 34 (black cable, white label)
Posted on: 03 September 2018 by Huge
The important difference is in the number and orientation of the pins in the DIN plugs.
5 pins 180° - Interconnect
5 pins 270° - SNAIC 5
4 pins - SNAIC 4
As Richard says, look at the FAQ.
(There are also a few specialised cables around as well with combinations of plugs.)
