DSD Files
Posted by: Mr Paws on 05 September 2018
Good Morning all,  Sorry I know this subject  has been covered on this forum but I’m new to DSD and was going to buy some DSD music today but I’m not sure which DSD to buy?
There are two available, 2.8mhz and 5.8mhz so I’m assuming,  going by what my SU can play,’single rate’ the 2.8mhz is the one to go for?
I’m also assuming that the 5.8mhz files are of higher quality hence why they are more expensive?
Thanks in advance chaps..????????
Posted on: 05 September 2018 by Mike-B
Yes,  with SuperUniti & all the 'legacy' streamers 2.8MHz is the one to go for.   2.8MHz is also labelled DSD64 by some vendors to add to the confusion,  the 64 number indicates its 64x faster than CD.   2.8MHz (DSD64) is aprx eq to a sample rate of 24/88.2kHz.
Posted on: 05 September 2018 by sjbabbey
@MR Paws
Which file format will you be purchasing? If there is a choice you should opt for .dsf rather than .dff files as dsf files support metadata tags whereas dff files do not.
Posted on: 05 September 2018 by Harry
What Mike said.
Posted on: 12 September 2018 by Mr Paws
Yep just bought my first DSD and it’s rather good..
Thanks Guys ????
Posted on: 12 September 2018 by Obsydian
As mention Naim DSD64 only, anything higher will not play.
I purchased a few favorites to play form USB, simply sublime.
Posted on: 12 September 2018 by Dalamtian
Obsydian posted:
Where did you download them from as I’m thinking of doing the same?
Nick
Not sure if we can link, if you Google i used the one that starts with HD ...
Posted on: 12 September 2018 by Guinnless
Obsydian posted:
My Naim nDAC plays DSD128s just fine
Posted on: 13 September 2018 by Mr Paws
Yep I got mine from HD****** on a discountcode so happy days.
Ill post a bit more info on the Music Room.
Posted on: 13 September 2018 by Dalamtian
Where did you get the discount code?
Nick
Dalamtian posted:
Nick
On the US  Website..
