New Naim App and radio presets
Posted by: Michael on 06 September 2018
I am still unable to edit my radio presets on my ND555 with the new app.
if I go into qB room the facility is there as it always has been with the option to edit presets showing at the bottom of the list.
When I go into the ND555 room that option is not there. Am I missing something?
Posted on: 06 September 2018 by Pcd
Micheal, I had a ND555 on demo and also encountered the same problem.
I contacted Naim and within a few minutes Phil Harris responded that they were aware of this problem and would incorporate a fix in the next app update.
Trust you are enjoying the ND555 I'm awaiting delivery ??
Posted on: 06 September 2018 by hungryhalibut
You cannot do it with new platform boxes. Less for more.
Posted on: 06 September 2018 by Michael
Pcd posted:
Yes I was rather hoping this new update would solve the problem, but good to know Phil and the team are aware of the issue.
Yes the ND555 is a stunning piece of kit as you will have read from the thread in other section. You are in for a treat! Hope the wait is not too long for you.
