Airplay2 Home-app not detecting Atom & Mu-So
Posted by: Herman-Vilvoorde(BE) on 08 September 2018
Has anyone tried out airplay2 to play multiroom on multiple devices? I follow the instructions in the Home app (apple) but Atom neither Mu-So are recognised as room; they are in the same network as my Ipad. In the app there is also a possibility to set a code or scan a QR but the implementation of Airplay2 has been via upgrade Naimapp.
Posted on: 08 September 2018 by David Hendon
I don't think Naim have actually released the Airplay 2 upgraded firmware for any of the players yet.
best
Posted on: 08 September 2018 by Herman-Vilvoorde(BE)
You'right David, i confused between app-update and firmware update, see: https://forums.naimaudio.com/t...-so-and-uniti-ranges.
Thank you,
Herman
Posted on: 08 September 2018 by ChrisSU
Herman, do you have a Mac computer? If so you can use Apple Airplay multiroom without waiting for Airplay 2.
No Chrissu, i've only Ipad, PC and Androidphone, thx  for asking.
Herman
