I am having a bit of trouble setting up my new cartridge - Ortofon Quintet Black.
I had one previous that tracked perfect with no distortion however it came to a sad end when I knocked it with my finger and the stylus pinging off!
I replaced with with a new one making no adjustments other than alignment when fixing it to the head shell.
I noticed strsight away on my favourite record some distortion, only on certain passages.. I quickly checked everything: Alignment, SRA, azimuth - all fine.
My preamp is/was set with 70db of gain. The cartridge is 0.3mv output. I noticed if I dropped gain to 60db the distortion that had crept in previously in certain passages (on the left channel) disappeared *phew* however the volume is noticeably less than when streaming.
Would 70db be enough to cause marginal distortion?
Staying with 60db gain where the distortion issue is resolved, there appears to be two ways to raise the analogue channel output volume on the nova in the input settings to bring it more in line with the volume when streaming (other than using the volume dial):
1) Raise input trim to around +7 from 0
2) Change input sensitivity settings from HI-FI (2.5V) as was to -> TV/AV (1V)
Does anybody know what ought to be the preference? Either don’t bring the distortion back however I do potentially detect (can’t be certain) a higher noise floor when changing option 2 rather than option 1.
Hopefully somebody might be able to offer some advice in this very knowledgeable forum!
Many thanks and happy listening
Posted on: 11 September 2018 by Richard Dane
Leon, I think it's rather difficult to advise here. I don't really know your cart or phono stage very well. I would go with whatever Arcam advise for their phono stage as the best match gain-wise for your cartridge. Too much gain may well result in possible overload and hence distortion, as headroom is reduced. Either way, even after phono eq and pre-preamplification, level from an analogue source will always be slightly lower than the level from digital (thanks to the rather high 2V level set by CD redbook - vs. about 1/3rd of that for even the highest output analogue sources), however AFAIK the Nova does give you some option to trim levels.
Most of all, trust your ears and go with what sounds best to you.
Posted on: 11 September 2018 by TallGuy
Leon,
I don't have the Arcam phono pre-amp, nor the Ortofon cartridge but I think I've experienced what you're describing - initially I had my Nova set to 2.5V, with my Rega phono preamp. I found the sound was better when set to 1V and the level was closer to that from the streaming part of the Nova so I've left it there.
Electrically you can use any of the three settings - if you hear distortion or it's too quiet change it - which is what you've done.
Finally, check whether the lid of your turntable and the record have a static charge in them - if you play with the lid down it can have an effect on the apparent tracking force which can cause the distortion you describe; this affected my turntable when new until I worked out what was going on and treated the lid with anti-static spray (I'm assuming your turntable has a plastic lid - I'm not familiar with it).
Posted on: 11 September 2018 by yeti42
Did you use a local dealer who may be willing to check out your new cartridge or are you on your own with this one? If it distorts at a setting where its predecessor (quintet?) worked fine and assuming you know what you’re doing aligning it, it suggests a fault. Can you get it checked in another deck and maybe on a high powered stereo microscope if available to see how the diamond is aligned in the cantilever and if there’s any damage.
Posted on: 11 September 2018 by Pev
I have had as a preamp Naim 62, 82, 52, Uniti, Superuniti, and Nova. On every single one of them the phono input was significantly quieter than the others. On the Nova, input trim is only a limited help.
Just turn up the volume when you listen to vinyl (and don't forget to turn it down again when you change source!). There is nothing wrong - it's just a quirk of Naim pre amps. Set the phono stage to the best sound and adjust the Nova volume - it will have plenty of welly.
Posted on: 11 September 2018 by Leon Wadsworth
Thanks Richard. Could I ask then; Is there a correlation between the lower level than 2V for CD and the input sensitivity settings on the nova (0.5V , 1V, 2.5V and 5V)? If so it should follow that selecting 1V is probably more appropriate. Sorry if that’s a daft question!
Kind regards
Leon
Leon,
Hi Tallguy,
Thanks for sharing your experience and confirming there is no issue with what input sens is selected. Either trim or sens gets me there so I guess it comes down to personal preference?
I don’t have a lid on my TT. It’s on a shelf covered that way but again, thanks for the food for thought!
Kind regards
Leon
Hi yeti,
I did use a local dealer and have spent £1,000s so wouldn’t be an issue to go and raise it I guess. It did occur to me there must surely be variances with cartridge production that could cause this sort of thing and having overcome the distortion issue by lowering the preamp 10db and raising trim, on the confirmation of this being of no detriment I should have cracked it without having to go through going back to my hifi shop. But you are right and I have pondered the same; Perhaps there is an issue? You wouldn’t expect such a variation. I suppose though if one cart was on the verge of breakup at that setting whilst the other was just tipped over then it may only be a minor variance.. Who knows! The final aspect is I do hate returning things. Just the look on a salesman’s face is enough to put my off going back! ???? Not saying they would be anything less than accommodating; I had to return a brand new pair of B&W wireless headphones that weren’t right and these were replaced absolutely without qwarm. But yeah, returning items is awkward for me, the whole explaining the issue, as if you have to put forth a convincing argument to get the end result I hate that! ????????
Thanks for chiming in
Leon
