Gapless Tidal
Posted by: Nisse on 16 September 2018
Hi,
Suddenly, gapless is not working using Naim app. Upnp works, but not Tidal. It has worked before. It's VERY annoying.
Does someone else have the same problem? Is there anything I can do to fix it?
Posted on: 16 September 2018 by RevoliƱo
Still working on my NAC-N 272.
Maybe a reboot of your equipment will do the trick?
Posted on: 17 September 2018 by Nisse
I have the 272, same as you Revelino. Done reboot, didn't help. Perhaps I should reset factory settings? As I understand it, it is the streamer that controls the gapless playing. Am I right?
The problem can easy be heard on Pink Floyd, DSOM, and lots of other albums.
