UnitiCute2 with NAP100 speaker settings
Posted by: Mike Sullivan on 21 September 2018
is anyone familiar with the speaker settings on the UnitiCute2 when running a power amp. I had it set to “large”, but reading a blog on The Ear, it seems it should be set to “none”. I found the manual a bit confusing, so now not quite sure which is correct.
Posted on: 21 September 2018 by Richard Dane
If running with a separate power amp then I think you set it to None.
Posted on: 21 September 2018 by Mike Sullivan
Richard Dane posted:
I think you’re right and I’m wishing I knew this 5 years ago. Upwards and onwards ???? Then again, I’ve on,y just updated the firmware for Tidal and multi room with the Nova, so pretty well set up now.
