Can I use my Naim Uniti Core as though it were a NAS or Sonic Transporter and connect it to my router via Ethernet?
Posted by: Echolane on 24 September 2018
I am a little unhappy with my Uniti Core.  It’s done a beautiful job of ripping, but now that I’ve graduated from absolute novice I see it’s limitations.  It doesn’t do subscription services like Tidal or Primephonic, etc.  It doesn’t do Roon. And I’m having problems with it.  I can’t see it’s internal SSD on my Windows 7 System, so I can’t download hi-res music to it.  It keeps quitting on me. Just stopping in the middle of playing some music.  It’s done this many times off and on, and yesterday it quit on me twice.   It’s color display has disappeared on my iOS app.  The albums are just a white outline in a black background.  I wrote support about these issues and no answer a week later.
I’m thinking of selling it.  I had a Sonic Transporter in my shopping cart at Small Green Computer just yesterday when it occurred to me that maybe I could use the Uniti Core in just the same way as a Sonic Transporter by attaching it to my router with an Ethernet cable and treating it like a NAS or Sonic Transporter.
I would need to put a Roon ready music server in its place to feed my DAC.
  If Roon Core was installed on my computer it should see my WAV files, right?
But now I’m not sure I see a way to continue to use it as a ripper.  I do like it as a ripper, but if I can’t continue to use it as a ripper,  maybe it’s  not worth keeping around after all.
Posted on: 25 September 2018 by Pcd
Better  to connect the Core  to the ethernet using a ethernet switch then you can use it at your NAS.
Why it is stopping playing I would suggest you involve your dealer to help and sort.
I'm quite surprised how many people buy a Core then realise it does not have any IRadio or subscription services?
Posted on: 25 September 2018 by Mike-B
Pcd posted:
Question is what was the dealer involvement   ...........   A Core sir,  certainly,  that'll be £1900,  anything else,  something for the weekend maybe.
Posted on: 25 September 2018 by Mike Sullivan
Have you tried deep sleep and wake up and a reset of your router? I had trouble seeing the Core on my Mac intially and had to discover it through my network, not sure how you would tackle that on windows, but I would think its a computer or network setting issue, rather than the core per-sue. Once you can see it, you simply drag and drop files into the download directory and they appear through the Naim App.
Posted on: 25 September 2018 by Echolane
 A music savvy family member recommended it and acquired it for me.  Which means I didn’t go through a dealer.  I have to take the blame for it’s purchase.  I didn’t have a clue at the time that I’d want to do more.   Now that family member has gone back to school for a Master’s and is crazy busy.   I can’t in good conscience bother him with this.
I don’t  follow your recommendation to use a switch.  Perhaps I have t been clear in my explanation.  Right now this is my situation:
Bedroom:  Windows 7 Desktop > Router
Living Room:  Ethernet > Naim Uniti Core > Audio Alchemy DDP-1 DAC > Integrated amp
Bedroom at one end of house; living  room is at other end of the house.
I am proposing this:
Bedroom :    Windows 7 Desktop*  > Router > Naim Uniti Core ***                                                *Roon Core
Living Room:  Router > Ethernet >  Audio Alchemy DMP-1 Music Server > Audio Alchemy DMP-1 DAC ** > Integrated amp        ** Roon ready
***Or I could sell Naim Uniti Core and transfer my WAV files to a Sonic Transporter w/ Roon Core and substitute it for the Naim.  And use dbpoweramp as a ripper.
I have reset my Router to no benefit.  What is “deep sleep and wake up”?
i do agree it is probably a network problem.  I have considered hiring a computer tech to sort it out for me.
Echolane posted:
Deep sleep is pushing down the power button for three seconds. Then when you push the power button again, the Core wakes up into active mode. It's effectively the same as a power off/power on and can resolve discovery issues across the network.
Regarding your setup, the Core can be wired into your network from any location through ethernet. The switch is simply taking one ethernet connection in, and sending it to a number of ethernet outs to multiple devices. You would, for example run a lead from a single ethernet port into the switch and then connect computers, Core, Apple TV's etc from individual leads connected to the ethernet out ports on the switch (the same as splitting electrical outputs on adapter boards).
Posted on: 25 September 2018 by ChrisSU
Echolane posted:
.....maybe I could use the Uniti Core in just the same way as a Sonic Transporter by attaching it to my router with an Ethernet cable and treating it like a NAS or Sonic Transporter.
Surely you already have the Core connected to your router, otherwise it would have no internet connection for metadata lookup, the Naim app wouldn’t see it, and your PC wouldn’t find it either?  It can certainly function as a NAS, or perhaps you mean a UPnP server, as that’s what it is, amongst other things.
If you run Roon (on your computer, or another device) it can certainly access the music on the Core, although it becomes harder to justify the price as, apart from its ripping function, you could achieve the same thing with a USB drive for £100 or less.
Posted on: 25 September 2018 by SimonPeterArnold
Personally I would use a sonic transporter as it gives more flexibility than Naims implementstion of upnp and it's self can be used as streamer to a dac, run other music management software and rip your CDs to a format you want rather then the one Naim chooses. It also will output at a higher resolution if using usb and if you want Roon it's a no brainer.
That’s really my thinking too. Except the Sonic Transporter can’t rip my CDs.
what would I have to do to keep the Naim as a ripper?   If I understand things, and I’m not at all sure I do(!), I’d have to do this:
1)  keep it on the network,
2)  transfer it’s file contents to the Sonic Transporter,
3) rip to its  hard drive, then transfer that file to the SSD inside the Sonic Transporter.
Would that work?  If so, it sure would be an expensive ripper.
Posted on: 25 September 2018 by Morton
You could sell the Core and buy an Innuos Zen mini, which would give you access to internet radio, Spotify and Qobuz as well as being a cd ripper.
Put DBpoweramp on your computer, and you will not need the Core as a ripper. Another alternative would be an Innuos ripper/server. This also has Roon, Tidal, iRadio etc. so may be a good single box solution.
Posted on: 25 September 2018 by David Hendon
Or you could use the Core as a ripper, store and server the way Naim intended, which is connected to your router by ethernet and then use a streamer connected to your amplifier to pull music from the Core by upnp under control of the Naim app.
best
I am much interested in Roon.  Will the scenario you suggest work with Roon?
Echolane posted:
Yes it can if you get the i7 ap version and ask for no storage  as you can then go and fit the SSD from your Naim Core. If you email the creator he will give you a quote for exactly what you want. You can configure them how you need them. With large storage already or without. It's cheaper without and you have your own.
ChrisSU posted:
They are not Roon certified and under spec for heavy duty Roon work. Better as an endpoint than a server.
Morton posted:
Not if you use it as a Roon server or Roon endpoint which the op wants,  it's all turned off. It's what stopped me from buying it and it's low specced for server to run Room.  If you use it only as upnp then it's fine.
I have already corresponded with Sonic Transporter and (good news!) he will fit my SSD inside the Transporter.  But why would I need the i7 version?
PS. I can’t seem to figure out how to quote.  How do you do that?
Tap on "Take action" and select "Reply with quote"
David Hendon posted:
Thanks ????????????????
SimonPeterArnold posted:
ChrisSU posted:
It’s true that Innuos servers are not full fat Roon devices, but given that the OP has, as far as I can tell, a DAC, not a streamer, maybe still worth considering. If you want to use the Roon DSP heavily, this would likely require a separate computer to run the Roon Core, but the Innuos could still have a place in such a setup.
Echolane posted:
Why not. Future proofs, allows more endpoints, larger library capacity , faster and allows full fat DSP without worrying about the speed of the thing. Also it cd rips so if you sold your core you could possibly but this and have some change (possibly)
To summarize, it does sound like I can use the Uniti Core per my original query.  And move to Roon.   All I need to do is this:
   Ethernet > Naim Uniti Core* > Audio Alchemy DDP-1 DAC > Int. Amp                               *Replace with Roon ready Audio Alchemy DMP-1 and connect Naim to Router in computer room.
If I like Roon, and I prefer it to the Naim app, I could  buy a Sonic Transporter, arrange to move my SSD to the ST.   And then  figure out whether to keep the Naim as a ripper only or just sell it.
I would just put Roon on any spare computer you have, for now, and do the free trial. If you like it, you can decide later on what sort of device you need to run it on. You may never want to use DSP etc.
Posted on: 26 September 2018 by SimonPeterArnold
Echolane posted:
Not sure if you using Windows or Mac as  core but be aware Windows 10 blocked smb1 in a recent update and you will need to enable it again or the Naim core might not be seen by windows and the Roon Core software. The core I believe uses an older version of smb a number of users have had issues using the Naim core as storage for their Roon systems. YMMV.
Posted on: 26 September 2018 by Echolane
I’m using Windows 7 Pro.  I do remember the thread about that problem.  I’ve already had a problem seeing my file.  However, I did a backup and as I recall I could see the backup file.  (Very odd.)  Here’s an article I came upon right away.  Perhaps it will be helpful.  Worst case, I’ll hire a tech to come to my house,
How to detect, enable and disable SMBv1, SMBv2, and SMBv3 in Windows and Windows Server
Applies to: Windows 10 Pro released in July 2015Windows 10 Enterprise released in July 2015Windows
I do so dislike these technical problems.....
