Upgrade to 552 - NDX 2
Posted by: ChrisBerlin on 25 September 2018
Hi,
today my system consists of a NAC 272 with XPS DR, NAP 300 (non DR) and Superline with HiCap DR adding a Rega RP 10. When listening to music the sources are the RP 10 as well as the streamer of the 272 - about 50:50.
I am considering to upgrade my system with a new pre amplifier. I very much like the naim sound, so that I think of a 252 or a 552. I have to add a separate streamer. This would be a NDX 2 powered with my XPS. I will have a demo of these components next weekend. Is it the right way to go or are the naim pre amplifiers a bit to old and will they be replaced in the product range soon? Then it might be the right way to wait for the new generation.
Posted on: 25 September 2018 by ChrisSU
Given where you are now, that sounds like a reasonable way up the Naim ladder to me. I’m not sure the Naim preamps are in for a revamp any time soon, but we will never know that for sure until any new product are actually released. By all means wait and see, but don’t hold your breath!
Posted on: 25 September 2018 by Allan Milne
Look back over the forum archive and you will see many, many comments on new pre-amps and N272 replacement … and nothing has happened.
Unless there are firm rumours going about, live in the now; that is why I have a 252 on order
Allan
Posted on: 25 September 2018 by Gazza
I just bought a 252 when my ND555 arrives. It did cross my mind about preamp updates, but life is too short to wait IMO. Naim have updated the preamp power supplies to DR relatively recently......and as a Chris says you only get a short warning of imminent product change.
Posted on: 25 September 2018 by The Strat (Fender)
Even if there were a new range of pre amps the old ones wouldn’t be redundant.
Your 300 is obvious going to be an excellent partner for either a 252 or 552 but you will need to get an audition to decide which you prefer, they are different beasts.   I personally if funds were ever permitting take a 552 but the 252 has a very mature analytical sound and is VERY engaging.   I heard the NDX2 last week it is a very very capable streamer particularly with a 555 PSU - sorry!
Good luck.
Lindsay
Posted on: 25 September 2018 by Mr Underhill
Don't discount the 282, you may prefer it to the 252.
Posted on: 25 September 2018 by hungryhalibut
It’s worth hearing what a 555PS does for your 272. I found it to make a huge difference. Having in the past owned a 252, which I found really boring, and a 552, which is just wonderful, I’m very biased and but wouldn’t recommend a 252. A 282/Supercap and an NDX2 would be a good way forward, but I’d certainly try it against a 272/555 to see if you think the price difference is worth it.
The old fish makes a worthy point vis a vis the 555 PSU.   It has made my CDS3 so joyous that I have dismissed any thoughts of a streamer at least for the foreseeable.
As a 282 user I don’t however hold with the view that the 252 is boring in my opinion it just gives a different insight.
Lindsay
Posted on: 25 September 2018 by Antonio1
To improve your system you should go separates, no question to me as nothing else would help improve massively your system ,the analog rig as well.
At that stage a 282 will do, much better obviously a 252. If you go for the former you could power it off your hicap dr and match the superline  but as a stop gap as  a supercap would be my sstrong advice. Nothwithstanding the 252/superline would definitely be the ultimate move assuming the ndx2/XPS DR would show itself to be as good as promised.
Posted on: 25 September 2018 by ChrisBerlin
For me the 282 is not the right way. I have had an audition of 272 with XPS vs. 282, SC and NDX. The improvement in sound quality was not worth the money to my ears. The main reason why I am thinking of a 552 is, that it would be the end of the ladder of upgrades - at least for the pre. The 252 is in the audition, because I want to hear the different types of sound. Today I do not really know, what I will love more. But I do not want to go several steps of upgrades over the years.
Posted on: 25 September 2018 by antony d
a few options for your to consider with out changing the 272 from my point of view, before you commit to NDX2 +++ and I agree with you NDX/XPS is not worth the upgrade, however adding 555 is a totally different matter
as HH says consider a 555 for the 272, and (or) DR your 300, believe me it takes an already superb AMP on to another level  (had mine DR'd earlier this year)
but in saying that lot's of people say on here the 252 is the natural partner for the 300? some think so, and I am more than happy with my 282/HCDR
Posted on: 25 September 2018 by S3
I found the 272 preamp really held back what my RP8 was capable of even with a 555DR powering it. Replacing the 272 with a 252 I’ve gone from virtually never playing records to it being my preferred source.
With a RP10 I’m sure the improvement will be equally, if not more, dramatic.
ChrisBerlin posted:
I guess the cost of the Supercap makes the latter a rather expensive setup. I thought NDX/282, powered by 200DR, was preferable to 272/XPSDR, although I could happily live with either.
So, I am looking forward to my audition on the next weekend. I think, that a 552 with NDX 2 or RP 10 is another level than 272 even with a 555...
Yes, of course it is. You’d jolly well hope so for the extra £20,000.
Posted on: 25 September 2018 by MDS
The 552 will not disappoint. While there's regular debate on here about 282 v 252 (a flavour of that given in this thread) there seems to be consensus that the 552 is head & shoulders better than both.  That said, the price ticket is eye-watering, so it damn well should be excellent.  Leaving aside the dizzying heights of an S1, another  advantage of the 552 is knowing that in pre-amp terms you're done.
Finally, if you are tempted to spend that much on a 552, it's well worth thinking about the rack and where it is going to sit.  It's a fussy beast.
Posted on: 25 September 2018 by Drewy
I’d go 555ps with the 272 first. Maybe then a 552 and find an NDS to go with the 555ps?
Posted on: 25 September 2018 by Chag...
I wouldn’t dismiss the 300 DR upgrade, it is a must. I also tend to believe that once at 552 level, one has to go ND555. ????
Chag -
Posted on: 25 September 2018 by Zackwater
My naim journey started with the 272, now I’m at 552 waiting for my 500dr and nd555 to arrive.  Good luck. All I can say is that the 252/300/nds is a very nice combo.  Wonder why I didn’t stop there?  For the price difference between the 552 and the 252 you can do a lot of upgrading.  Plus the price and availability of used NDS’s make them quite attractive.  Get with your Naim dealer and weigh all your options, there are lots of good choices.
Posted on: 25 September 2018 by Richard Dane
If you do go for a NAC552, then you should try listening to the Superline powered from the 552's AUX2 against a dedicated Hicap.  You may well prefer the former...
Posted on: 30 September 2018 by ChrisBerlin
Richard: That does not work in my system. I have a distance of 4 m between my Superline and the preamp. You know of the earth problems I have had in the beginnings. The solution was a bit of cable dressing.
Posted on: 30 September 2018 by Richard Dane
Chris, I'm pleased to hear you managed to sort it out.  The Superline can be a sensitive thing...
Posted on: 30 September 2018 by Bob the Builder
ChrisBerlin posted:
I have the same issue albeit with a different system I have to have my phono stage well away from the rest of the system on a shelf above the record player.
If you can afford the 552 then that would be my choice and then depending on how much you want to spend on a streamer NDX2 or ND5XS2.
The 552 is a wonderful black box - ok, two boxes! I heard it with my old 250 and with my 300 in the current setup. It was amazing how much control the 552 brings in the system with the 250. The round sound of 250 was blown away. And with the 300 it sounds impressive. Now I know what my turntable and the Superline is capable of. When listening to my vinyls I have had a permanent grin on my face...
The NDX 2 with XPS DR and the 555 were demonstrated at my dealer. I have also listened to the 252 with Supercap in comparision to the 552. It felt like there was a curtain lifted when we changed to the 552. The difference between NDX 2 and 555 was also amazing, but the invest in the 555 with a new power supply is a bit to big. But the 552 is a wonderful end of the ladder - at least for the preamp.
Posted on: 30 September 2018 by Simon-in-Suffolk
Richard Dane posted:
Richard interesting... is that your preference? Or are you simply pointing out it’s a possibility.
