NAC 72 vs 102 The Final Verdict
Posted by: mikeybaby on 25 September 2018
I know this debate has gone on for some time time but I hope this post will put it to rest once and for all.
Both are excellent preamps and will outperform much of the competition for a fraction of the cost, but when deciding between the two here is what I found. System for both was identical. CBNap250/CBHC/CDS/SBL/NACA5. The 72 is better IMO because it has more clarity, a warmer presentation , more of a live sound.,tighter bass and sounds like you are in the front row. The 102 sounds a slight bit more open and airey but at the cost of all these other critical factors. As I said both are very good but the 72 is truly a special preamp that will continue to be praised by audiophiles around the world.
Posted on: 25 September 2018 by naim_nymph
Apparently the design of the 102 is basically to use an expanded version of the 72 motherboard made to fit inside a full width box, If this is true (?)  ...then it's very odd how these two pre-amps differ so much in voicing character.
Having owned both, i can appreciate the pros and cons of each, and can only surmise that if one took the good points of the 102; it's clarity and wide bandwidth of frequency, and the good points of the 72; it's warmth and analogous musicality, and then put the best of both together, the performing result would sound something like a well tempered NAC 52 : )
Posted on: 25 September 2018 by Suzy Wong
You are, of course, entitled to your opinion, and I will defend your right to give it.........even if it's wrong.
naim_nymph posted:
or an 82?
Posted on: 25 September 2018 by mikeybaby
Too dry.
Posted on: 25 September 2018 by ChrisSU
Perhaps there is a high chance that sample variation will affect your findings, especially given the age of these preamps.
Posted on: 25 September 2018 by Bob the Builder
mikeybaby posted:
Well thats that then glad you put us all straight on that one. What's your thought on the chicken and the egg?
Posted on: 25 September 2018 by Obsydian
I went 32.5, 72, 102, 82, 52, my favourites where the 72/52, the 102 I thought was a downgrade rather than upgrade.
