Naim Uniti Core keeps suddenly shutting down. And a few other things. No response from support.
Posted by: Echolane on 26 September 2018
I have a Naim Uniti Core a few months old.  It holds an internal SSD of 1TB WAV music.
1) It has developed an increasing habit of shutting itself off in the middle of a music playing session.  Music will stop.  I will look up and see the unit has turned itself off.  I will turn it back on and resume playing.  Several days ago, it did this twice in one day.  What could be causing this?
2) I can also add, that I’ve struggled with my DAC which displays an invalid message when it doesn’t recognize a proper digital signal (such as a digital format it can’t process).  But I have only redbook CDs on file so far.  This has happened inexplicably several times.  Could it be the Uniti Core sending a garbage signal to my DAC?
3) The Display on the Naim app has gone black and white for the last 4 days.  Albums are displayed as boxes outlined in white on a black background.  Can’t figure out how to restore the normal album cover pictures and color.
4)  I can’t “see” my music when I open Windows File Manager.  As a result I can’t download other music to  my SSD.
i have contacted Support with these issues,  but have had no response.  I don’t have a dealer to call on so I hope the support community has some clues that might be of help.
Posted on: 26 September 2018 by SimonPeterArnold
Sounds like you have a lemon that needs an RMA.
Posted on: 26 September 2018 by Cbr600
Check the core set up and change the power off setting to never, to see if this helps with the shutdowns. The other issues sound like network related matters.
Posted on: 26 September 2018 by David O
I having core issues also, music stopping via SPDIF, however, will play via upnp....I too have contacted Support via email three times but no response...
Posted on: 26 September 2018 by James G
I raised the issue of the Core going to sleep when playing through SPDIF with support back in May. The RnD department were able to recreate the issue - the Core does not always recognise there is a signal on the SPDIF and goes into standby according to the Auto standby time set via the app. I chased a fix for this last week and had a response on the 19th informing me Naim are in the process of testing the update.
My solution was to change the auto standby sleep setting from 20 minutes to 6 hours.
Posted on: 26 September 2018 by Echolane
James G posted:
That sounds easy!  Thanks.
I am new to digital; perhaps I could be called an analog dinosaur ????.  So I need a little help interpreting some of the many digital acronyms, like SPDIF. My Naim Uniti Core is connected to my DAC via BNC to Coax.  Is Coax the same as SPDIF?
Posted on: 26 September 2018 by ChrisSU
There was a similar issue with the Atom going into standby when some inputs were selected, specifically Qobuz via Chromecast, which could be resolved by setting auto-standby to Never. Not sure if this was ever fixed, as I ditched Qobuz after the free trial.
Echolane posted:
James G posted:
Yes, a coaxial cable with BNC connectors is what you use for an electrical SPDIF connection. As opposed to an optical SPDIF connection, aka Toslink.....or a network connection via Ethernet cables.
Posted on: 26 September 2018 by bongoman
James G posted:
I had the same issue with my Core. I've playing mine via SPDIF into the nDAC with auto standby set to 10 minutes without any problems. However, recently it has started shutting itself off after 10 minutes during playback. Interestingly, this coincided after I updated the Naim app so I'm guessing this isn't a coincidence.
My solution was to also change to auto standby sleep setting from 20 minutes to Never. I just turn it off manually which obviously isn't ideal. I'm looking to get a streamer soon so I expect I'll be using the Core in uPnP mode rather than SPDIF.
Hmmm....  I e just changed mine to 12 hours.  Maybe never is a better idea.
I am also wondering if my problems with graphics on the app coincide with updating the app.  My updates are done automatically, so I’m not aware of when it happened, though I know it was updated recently.
Posted on: 26 September 2018 by nbpf
Echolane posted:
James G posted:
From Wikipedia: "S/PDIF (Sony/Philips Digital Interface)[1][2] is a type of digital audio interconnect used in consumer audio equipment to output audio over reasonably short distances. The signal is transmitted over either a coaxial cable with [BNC or] RCA connectors or a fibre optic cable with TOSLINK connectors. S/PDIF interconnects components in home theatres and other digital high-fidelity systems."
Typically, S/PDIF (electrical, optical) is used to denote the interface. BNC, RCA (electrical) and TOSLINK (optical) denote the connectors. DACs can have S/PDIF interfaces, USB interfaces, Ethernet interfaces and others. DACs that have Ethernet interfaces are often calles "streamers". Devices with Ethernet inputs and S/PDIF or USB outputs are often called "network renderers". They are "digital transports": they do not convert digital signals to analogue signals (or vice-versa), they just convert between different digital formats.
Posted on: 26 September 2018 by Obsydian
Best to call Naim Salisbury and NOT the Uniti BOT line for an automated "human" response
Posted on: 27 September 2018 by Echolane
NBPF - Your reply was very helpful.  Especially helpful was discriminating  between the interface and the connector and learning the appropriate terms.  The terms make more sense now.  Thanks.
Posted on: 27 September 2018 by Rich 1
Rather than emailing support try phoning them, that's what I did when I had Core problems. They walked me through several trouble shooting sessions. Rich
Posted on: 27 September 2018 by Renato.Stein
My Core has just recently started playing albums on Tidal from the 2nd or 3rd song on and stopping 5-10 seconds before the end. Quite annoying... This seems to have gotten worse after upgrading to the new App version! I have rebooted the system, did all tricks I thought it would help but the problem is still there. When I play Tidal on my iPad this is not a problem. Any suggestions?
Posted on: 27 September 2018 by ChrisSU
Renato.Stein posted:
My Core has just recently started playing albums on Tidal......
Your Core plays Tidal? A few people here might be jealous!
Posted on: 27 September 2018 by David Hendon
ChrisSU posted:
What Chris means is that the Core won't do Tidal so it must be your streamer that has these problems with Tidal, not the Core.
best
Posted on: 27 September 2018 by SimonPeterArnold
ChrisSU posted:
Does the same on the analogue input.
SimonPeterArnold posted:
ChrisSU posted:
Mine doesn’t! I have standby set to the minimum, and it only overrides playback on Chromecast.
Sorry. I meant to say Uniti Atom. This is my equipment and it plays Tidal... Still, it is not working properly!
Posted on: 29 September 2018 by SimonPeterArnold
ChrisSU posted:
ChrisSU posted:
Do you use AV Fixed Volume? I do, and it turns itself off. It's random sometimes it's fine other times not. It's changed every firmware upgrade and I'm on my 2nd unit. So its a feature bug.
Posted on: 29 September 2018 by ChrisSU
ChrisSU posted:
ChrisSU posted:
I don’t know what AV Fixed Volume on an Atom is! I do occasionally use the HDMI ARC input from a TV, which is the only input it has with a wired connection. It’s been a while since I had this issue with Chromecast, so I’m not sure if it has since been addressed with a firmware update.
Posted on: 02 October 2018 by SimonPeterArnold
A
ChrisSU posted:
ChrisSU posted:
ChrisSU posted:
AV Fixed Volume is for analogue input and sets it as a pre amp in to take a preout from an AV amp so you can drive the same speakers for the front two channels of your 5.1 system. So AV amp does the rear, sub and center atom powers the fronts.
Posted on: 03 October 2018 by Renato.Stein
I have tried all possible tricks and with the recent App upgrade and current firmware version now the system does not recognize Chromecast. It keeps starting an album from the second or third song and it stops before it ends. Shame on you, Naim! And I have read several threads that talk about problems whenever there were upgrades. And Naim's customer service does not respond to my emails.
This is my second unit of the Atom (the first simply froze and it would not work anymore - it was changed at the dealer) and I am very frustrated with all that.
Should I go back to factory settings and try to restart the system?
Posted on: 04 October 2018 by David Hendon
You would probably get more responses if you started a new thread with a relevant title about Atom rather than posting on an old thread which is about UnitiCore.
Getting a reply to an email to Naim support is a bit hit and miss currently unfortunately. You could telephone them and at least talk to someone but their advice to anything that the person you speak to doesn't understand will be "go and talk to your dealer".
You certainly could try a factory reset of your Atom, but others who have an Atom and use Chromecast (I don't) may have other suggestions.
best
Posted on: 04 October 2018 by Richard Dane
Renato, as David advises above, I think it's best you start a new thread regarding the difficulty you are experiencing with the Core.  And before you do so, please do make sure you have involved your dealer. I will close this thread now so you can start a new one.
