Naim App and nDac
Posted by: lhau on 28 September 2018
Hi,
I am planning to get hold of a nDac to taste what R2R and possibly NDS and N555  taste like.
In my current system 272/xps/200, I presume I should put the xps and all my digital input into ndac? I am wondering if there is a way to conti .nue to select the input of nDac with the naim app similar to what I am.currently doing with n272?
Posted on: 28 September 2018 by ChrisSU
What you can’t do is take a digital signal out from the 272, into the NDAC, and back into the 272 analogue input. If that is your intention, you really need separates.
Posted on: 28 September 2018 by lhau
What I have in mind is: : Digital Sources/nDac/272/200 vs Digital Sources/272/200.
I am not sure if I can still use the Naim app to control switching between the Digital Sources.
You can use System Automation to control some CD players into a 272 via the app, or an NDAC from an NDX, but I’m not sure if an NDAC into a 272 would work. Maybe one for Naim support to answer.
