run-in / warm up for non NAP units
Posted by: gramophone on 29 September 2018
Ive got a Star with a 250. Ive been using them for a good while.
Im getting a NDX 2 in a few weeks (ready for me at dealers but I'm gonna be away so no immediate install). The NDX 2 will replace the star.
Ive got ex demo units stacked in boxes that will come into play once I get the new streamer: preamp + PS and a PS for the NDX 2. So I'm presuming these are run-in cos they're all at least a 2 years old. But they're not presently getting any current through them.
My question is should I plug them in, in readiness for the arrival of the new NDX 2 with which they will comprise my new system? Get them warmed up so to speak.
Posted on: 29 September 2018 by Suzy Wong
I’m sure your energy supplier will thank you............
Posted on: 29 September 2018 by gramophone
Let's assume I'm gonna "offset" the extra power consumption. The excitement of the anticipation has made me forget about washing my clothes and showering.
Posted on: 29 September 2018 by Tamarin
Assuming that the 2yo ex-demo units have been in steady use, they should already be run in. So in my experience, it should take no more than 24 hours for run in units to come up to temperature and thermally stabilize once powered on.
Posted on: 29 September 2018 by Richard Dane
With a unit that's already run in then it takes anywhere from an hour to 3 days to reach a performance peak.  In my experience, power amps are often (but not always - NAP300) quickest, which is why I sometimes switch them off if I know I won't be listening to music on them within the next 24 hours. However, if they have been unpowered for quite a while then it could take longer - at least 3 days.
In your case, I think that getting everything set up and powered up a few days before the NDX2 arrives is a very good idea.  It will also give you an idea of the performance and let you know of any possible issues with the s/h kit before the streamer arrives.
Posted on: 30 September 2018 by gramophone
Richard Dane posted:
thanks that's good
Posted on: 30 September 2018 by Tamarin
I defer to Richard. I live in sunny California where perhaps it takes less time to come up to temperature and stabilize ;-P
