NDX2 Not Playing All Files
Posted by: Crispy on 01 October 2018
i have now resolved this, but maybe of benefit to others if they come across it.
Discovered when playing some 16/44 files purchased from Qobuz that they would not play on my NDX2. They played on old NDX, home PC and other devices. Copied them onto a USB drive and they played fine on the NDX2,  but not from Synology NAS.
This morning I converted the original AIFF files to FLAC and these played ok. Then reconverted back to AIFF and they played ok. Bizarre.
Posted on: 01 October 2018 by Stevie Bart
I had a similar experience whereby my NDX 2 would not play some flac files that my old NDX would.
Turns out that it was just files that had been edited and saved using Wavepad that had the problem.
I downloaded a free copy of Ocenaudio and files edited and saved via this software play fine on my NDX 2
