252 Jumping inputs
Posted by: Zipperheadbanjo on 02 October 2018
Last night my 252 started switching inputs all on it's own. At first, I thought perhaps the remote battery was dying and acting wonky... so I removed the batteries. The phenomenon continued. Then I powered down and back up again. The phenomenon continued. Then I powered down, disconnected and reconnected all cables, and the phenomenon continued.
Then I powered down again, this time including the Audience Power Conditioner... and I thought that fixed worked. Well it worked at least for a few hours as it was good for the rest of the night.
Then when I woke up this morning, I noticed the input selected on the 252 was not the input I selected before bed last night.
Any thoughts on further trouble shooting steps I should take tonight when I get home from work... or and ideas what the problem might be?
Posted on: 02 October 2018 by Guinnless
TV or other remotes ? Put tape over the remote sensor to eliminate remote issues.
Posted on: 02 October 2018 by Richard Dane
Yup, check for any other remote control stuck down the side of a chair or sofa.
Posted on: 02 October 2018 by ChrisSU
Funnily enough, I was about to post about a similar issue with my 282. My NDX is on the CD input, and I’ve recently connected a DAC to the Tuner input. The DAC would occasionally cut out, but actually, it was just the NAC changing inputs. Initially I thought it might be because the NDX was in use as a transport for the DAC, but was also still connected directly to the NAC, so I removed the lead, but it has just done it again.
There is no other equipment in the room, no TV, no spare remotes.
Posted on: 02 October 2018 by Allan Milne
I agree that first thing I would do is mask out the IR receiver on the 252; then, if that solves it, figure out what is causing the IR interference.
I had a friend many years ago who had a similar issue with an entry-level Naim app (can't remember the model) and it transpired it was his plasma TV screen emissions that were causing the problem.
Good luck,
Allan
Posted on: 03 October 2018 by Zipperheadbanjo
Thanks for the feedback!
Much better than what I was fearing.
Posted on: 03 October 2018 by Bart
You’re not using System Automation are you?  If so that’ll do it if it’s set to the wrong input. I know this first hand.
