Dissapearing artwork
Posted by: JohnL on 03 October 2018
Hi All,
All my cd's are ripped to flac via DBPA to a qnap nas drive serving a Naim NDX. I have a couple of albums where the artwork has disappeared from the albums overview on the Naim app (the artwork is there when I open the actual album to play it). I have done the usual edit IDTag in DB (where it shows the artwork). I have removed the artwork and then re-installed it all to no avail. I have also done the "clear cache" and rescanned the qnap hard drive.
Has anyone got any thoughts on what I may be doing wrong (Naim app is up to date)
Many thanks
John
Posted on: 03 October 2018 by hungryhalibut
Have you cleared both the image cache and upnp cache?
Posted on: 03 October 2018 by JohnL
Hi HH,
That's a good point. Where would I find the "clear UPNP cache" option, only found the image one.
thanks
John
It’s under the upnp input settings in the app.
