Bluetooth cause general system crash and unable to play any music Nain Nova
Posted by: BeppeP on 12 October 2018
I have a Uniti Nova and tried to pair a mobile phone or laptop with bluetooth. Everything worked, however when i turned the bluetooth off on both naim and phone, everytime I turn on the Nova it shows no bluetooth device connected, strange because the option to search for devices is off from the application... I cannot stream anything or play internet radio, as last source I reset everything to factory settings and now it works. Do I have to do this trick all the time I use bluetooth? App is updated to last version and firmware as well.
Another issue now is Spotify connect will not connect, it finds the Nova but wont connect, so I have to stream via airplay. Please solve it asap.
Posted on: 12 October 2018 by Adam Zielinski
If you’ve reset all settings to a factory setting, surely Spotify will need to be set up from scratch.
as to your last sentence - this is a forum, not a support request desktop
Posted on: 14 October 2018 by sjw
As you seem to be a self professed expert on everything Naim Adam, I think it's a bit rich to say this isn't a Support arena... lots of people ask for help and I can see nothing wrong with that
Posted on: 14 October 2018 by Richard Dane
Beppep,
Spotify appear to have changed something fundamental - Naim are working to solve as quickly as possible.  See here for details and work-arounds:
https://forums.naimaudio.com/t...-via-spotify-connect
