Unitiserve
Posted by: dangerousdavejones on 12 October 2018
I have a question regarding the naim unitiserve I have a dac (non naim) with optical in and I noticed that the unitiserve has optical out could I use the unitiserve with a non naim dac?
Posted on: 12 October 2018 by Klout10
Yes, that should be possible ...
Posted on: 12 October 2018 by Bart
Yes, the digital output formats are fairly standard.  The UnitiServe manual will tell you the formats it can output -- your dac may be happier with more (or fewer formats) but overall you're limited to what the UnitiServe supports.
Posted on: 12 October 2018 by ChrisSU
You have a choice of optical or coaxial SPDIF output, and you should be able to use it with pretty much any DAC that has either of these inputs. The preferred connection by many Naim users is the coaxial one, but either would be fine.
Posted on: 12 October 2018 by dangerousdavejones
Thanks guys
