Unitilite
Posted by: Coll on 19 October 2018
I have had my Unitilite for approx 3 years and have found recently that the CD drawer jams when using it for the first time after a few days.
It usually opens the 2nd time I press the stop button but always jams the first. Is this a common fault.
Posted on: 19 October 2018 by David Hendon
Not one I have ever encountered with mine or seen reported in the forum either. You probably should talk to your dealer about getting it serviced by Naim. Or you could put up with pressing it twice when necessary.
best
