Supercap question
Posted by: Japtimscarlet on 22 October 2018
I think there is a difference between earlier and later Supercap power supplies...pre DR ...but cannot remember what ... something to do with what they can be connected to ...
Can someone remind me pls ?
Posted on: 22 October 2018 by hungryhalibut
I suspect you are thinking of the XPS. Pre DR Supercaps are basically identical, whether olive or black.
Posted on: 22 October 2018 by lyndon
the case was the only difference, been inside both
lyndon
Posted on: 22 October 2018 by Richard Dane
Main differences between the Olive Supercap and the Classic/Reference Supercap (pre DR); chassis, fascia, logo, sleeve cover, switch, feet.
Posted on: 23 October 2018 by Japtimscarlet
Ahhh is it the XPS I'm thinking of ..
Hope so as that opens the market up if all the supercaps are the same ( bar case etc. )
Thanks for that
