PS 555
Posted by: Mauricio Ichi on 22 October 2018
Hi guys,
I'm thinking of doing an up grade on my DAC. There was an opportunity for a PS555 220V. My question is if I can turn this PS to 120V.
Thank you in advance for your help.
Maurico
Posted on: 22 October 2018 by Adam Zielinski
There is no question.....
Posted on: 22 October 2018 by HiFiman
Adam Zielinski posted:
If you scroll his post the question is there, he wants to know if the mains input voltage can be changed from 230 to 120 on a Naim PSU.
Posted on: 22 October 2018 by Mauricio Ichi
My doubt was if the toroid did not allow the voltage change.
So just change the posts on the trafo, okay?
It's a question for Naim tech support and for them to make the change.
Posted on: 22 October 2018 by hungryhalibut
I think you need to send the 555 to the factory to be adjusted.
Posted on: 22 October 2018 by Richard Dane
It would need to be changed either by the Naim factory or by a Naim distributor with the service facility and experience to do so - it is definitely not a DIY job.
Otherwise your best bet is to purchase a 555PS for the American 115V market.
