Muso - Power light and volume flashing white
Posted by: iburnell on 28 October 2018
My Muso seems to be working just fine but the white power and volume light are flashing on and off, I've tried removing and re-adding the Naim app. Powered off the Router and switch it is connected to to no avail. Also tried discovering room manually which does state the white flashing light should go out but nothing happens
Thoughts?
Posted on: 28 October 2018 by Gazza
Have you tried removing power from the Muso, for a minute or so, then repower?
Posted on: 28 October 2018 by iburnell
I did switch it off an on along with the switch and the Router, but I haven't left it off for a while - I'll do so and let you know
That fixed it. Thanks!
Posted on: 29 October 2018 by Michael
I had the same thing a while back with my Qb. As you have discovered disconnecting the box from its power supply and rebooting seems to fix the problem.
