Headline
Posted by: Ivanhoe71 on 29 October 2018
My headline has stopped working! Green LED is lit, powered from a NAPSC. Receives signal feed from tape out of my NAC 202. Worked perfectly until recently, after un-cabling and relocating hifi to a new room. Yes headphones tested and work elsewhere just fine. Is the Headline input or NAC202 tape output 'protected' by any kind of fuse that may of blown?
Much obliged for any pointers?
Posted on: 29 October 2018 by Gavin B
Did you use the same / correct interconnect after the re-build? Remember the wiring is different from a normal interconnect.
Posted on: 29 October 2018 by Ivanhoe71
Thanks Gavin, though Headline only has it's own pre-wired input interconnect that I believe MUST be connected to the tape out of the 202 pre-amp? Power from a NAPSC.
Posted on: 31 October 2018 by Ivanhoe71
Hello, many thanks, didn't know that. Working now after many button pushes!
