connect 202 to 300dr
Posted by: French Rooster on 30 October 2018
the cables connecting nac 202 to nap 200 can be used to connect the nap 300dr?   thanks for the information
Posted on: 30 October 2018 by Richard Dane
No. the NAP300DR comes with it's own left and right handed DIN4-XLR interconnects.
Left hand (Channel 1) has a green band, right hand (Channel 2) has a red band.
Note that to connect a NAP300 to a NAC202, the 202 would need to be powered by a dedicated power supply such as a Hicap.  The Hicap then provides the pre-outs - there are three stereo pre-outs provided on DIN4s, of which you only need to make of use of two.
Posted on: 30 October 2018 by French Rooster
thanks Richard.
Posted on: 31 October 2018 by Huge
Mega Mullet!
Posted on: 31 October 2018 by cheeselet
Probably not a way to get the best from a 300dr.
No harm in trying!
Posted on: 31 October 2018 by Aceone
I had the 202 with supercar 2  with nap 300dr and it sounded great  .
