Help setting up remote link pls
Posted by: Japtimscarlet on 31 October 2018
I have a core into my NDS then connected to a 252
I have the correct ( I believe) remote control link cable to connect the NDS/252
Can I now use either the naim app or ine of the two remotes to control both bits of kit?
I'd like to be able to swop between tidal / core / radio etc and still be able to adjust volume / balance etc all from one place
I just don't understand if that's possible from the manuals?
Thanks for any help...
Posted on: 31 October 2018 by Japtimscarlet
Ok.. got the volume and mute working from the app now ...is there anything else it will do now NDS and 252 are linked that I'm missing?
Posted on: 31 October 2018 by ChrisSU
Sounds like you are sorted, although you can also control input selection etc. Have you read this?
https://www.naimaudio.com/site...ystem_automation.pdf
Still struggling with the auto input switching...
Put 252 in programming
Jog across to the input I want
Exit programming
Nothing changes??  Must be something I'm not doing...
