Display on Ndx2
Posted by: HamiltonNZ on 01 November 2018
I have been very lucky recently to be able to purchase an NDX2, what a great piece of kit. What I am not sure how to do is to turn off the display. I am sure I remember an earlier post on the same subject concerning the ND555, but I’m bugg£#ed if I can find it.
Secondly, rather than continuing to ask silly questions where do I locate a comprehensive manual on the NDX2? Looked on the Naim website, on the internet and nothing jumps out at me.
Any help greatly appreciated
Posted on: 01 November 2018 by Gazza
I don,t think you can turn the screen off yet?, you can for the ND555. In terms of a manual all you get is the quick start guide and the FAQ in the support section of the Naim product page for NDX2. This has been raised sanumber of times on the forum as being unacceptable, for example a pdf to download would be much better?
Posted on: 01 November 2018 by Pcd
Use the remote go into the settings screen you should see Display go into display and toggle the screen on or off as required.
Not sure on the Manuel look on the Naim Website they should have some info regarding the NDX2.
Sorry PCD is correct, use your remote as he suggests, settings, display , then turn off. I checked there is only a quick start guide, so you have to use FAQ in support page on the product web page.
Posted on: 01 November 2018 by Richard Dane
For the NDX2 online support guide see here:
https://www.naimaudio.com/product/ndx-2
