Repair of Gloss Speaker
Posted by: Aaron Sparks-carolan on 04 November 2018
Hi Guys,
I wonder if you could help, I have a black gloss speaker which has a very small nick in the gloss. Do you know if this is repairable?
Posted on: 04 November 2018 by Japtimscarlet
Depends on the finish
If it's piano black ..it's usually lots of coats of paint and lacquer with loads of polishing in between... A French polisher or furniture repairer may be your friend
If it's just a nick ...why not touch it in with a matching car paint and small brush ?  Should make it nearly invisible
Posted on: 04 November 2018 by Aaron Sparks-carolan
Great Thanks for your advise. Its for some old speakers so just wanted to be able to pass on some advise if the question came up.
