stageline s or 323-5 boards
Posted by: dolorem on 07 November 2018
Hi all ,
I know there has been a little on this on the forum but slight deviations in question. Just in the process of upgrading from MM to MC. not sure what cartridge yet. I'm running an LP12 into a NAC 32.5 with high cap then into a NAP250. Ive got two bids running at present on a Stageline S and 323-5 Moving coil boards. The cards obviously significantly cheaper but which will give the best performance.
Thanks in advance
N
Posted on: 08 November 2018 by Richard Dane
N, bear in mind that if you go for a Stageline then you will need another power supply - Flatcap, Hicap, or Supercap (good, better, best).  With your NAC32.5/Hicap I would stick with the NA323/5 MC boards.
