NDX1 and Linksys Velop
Posted by: Gordon Lau on 09 November 2018
I have just upgraded my router from Apple AirPort Extreme to Linksys Velop.
Problem:  I couldn’t get my NDX to recognise the new network.  When NDX searches new network, all I could get are some weird network names and none of them can’t be logged in.
Any clues please?
Posted on: 10 November 2018 by Rich 1
Have you tried resetting the ndx. Did you leave the ndx connected and 'live' while changing the router? Would be best to turn off. You may need to reset / reboot both. Search forum for correct order and method. Basically with everything turned off / disconnected on the network start with router leaving a few minutes for each component to fully boot before doing the same with the next. Rich.
I'm assuming that the rest of the network is working prooving the Linksys is set up correctly. Rich
Posted on: 10 November 2018 by Gordon Lau
Thks! Velop setup worked beautifully apart from NDX. Still couldn't it working. Maybe power down a week and restart again.
Or else buy another node and link the NDX via ethernet (perhaps will improve the sound...)
I don't have an ndx but did you originally set it up as static or plug and play? Rich
Posted on: 10 November 2018 by Mike-B
A question comes to mind & apologies as it might be off the track altogether:  I assume you are trying to connect over wireless,  what & how have you set the  wireless bands,  remember the NDX is 2,4GHz only
Posted on: 10 November 2018 by Bart
Gordon Lau posted:
No. A week offline will do nothing but deprive you of music for the week. It’s not like there’s some storage of internet in your NDX that takes a week to dissipate.
It only settings. Can be frustrating until you find which one but you need buy no further hardware.
Mike-B posted:
Yes.  Velop does have 2.4 too where my older devices hooked up without glitch.  Still wondering why just NDX won't work
