Remember to look after your connections
Posted by: NJB on 10 November 2018
i know this, so why did I get caught out today?  I powered everything up as usual, but left the 282 on mute.  I came back to the system some time later, took it off mute and the left channel was a wall of hiss.  Idiot, when had I last had all the interconnections off?  I found the culprit on the back of the HiCap, and all is now fine.  The pins on the interconnects will start to oxidise over time and the act of disconnection and reconnecting is enough to break through the oxidisation layer and get the metal on metal contact back to normal.  When I next power it all down, I will have them all off and back on again.  It is a simple cure for a simple problem, but I still feel like a muppet!
Posted on: 10 November 2018 by ursus262
I strongly recommend the use of Deoxit spray - it's amazing stuff.  I clean all my connections once a year as part of spring cleaning and it works amazingly well
Posted on: 10 November 2018 by Iconoclast
I've been using Deoxit for years but recently landed on a thread (somewhere) that claimed, that after initial cleaning, could actually end up doing more harm than good.
I was told by a Furutech rep that one of the best things to clean AC plugs is VIM (kitchen cleaner) or ceramic stove top cleaner and a soft toothbrush. You could always follow up with Deoxit Gold as a preventive measure. I tried it and could swear I heard an immediate improvement.
While we're on the subject...if connectors oxidize, what about the inputs?
Posted on: 10 November 2018 by hungryhalibut
Unplugging and replugging connections is all that’s needed, and any cleaning products should be avoided, as they can leave residues. When unplugging and replugging you should do it several times - some say 10 or 20. It’s a good idea to do it a couple of times a year, to keep everything tip top.
Posted on: 10 November 2018 by Mike1951
This ^^
Posted on: 10 November 2018 by Peder
hungryhalibut posted:
Unplugging and replugging connections is all that’s needed,????"and any cleaning products should be avoided,as they can leave residues"
I really have to agree with what Hungryhalibut writes above.
This is very important,and part of the regular maintenance of your music-system.
◾And this is even more important:????HH wrote "and any cleaning products should be avoided,as they can leave residues"
So do not use cleaning products.!!
/Peder????
Posted on: 10 November 2018 by Richard Dane
Naim advise against using liquid contact cleaners and “enhancers” - better to just let the contacts self clean through plugging in and out.
Posted on: 10 November 2018 by Loki
Richard, do you think that advice holds good for all hifi or just Naim products?
Loki, I guess Naim’s advice refers to their own connectors, ie DINs and 4mm plugs and sockets.
Posted on: 10 November 2018 by Huge
DINs have high pressure "self cleaning" contacts - unplug and reinsert the plug once each year is sufficient; a maximum of 2 times in the same period if you're paranoid!
Loki posted:
???? Loki,....It as Hungryhalibut,me and Richard wrote applies to all contacts,..Regardless of brand.
Now just answered Richard on the subject of Naim's advice,..but as I wrote above,this generally applies to all contacts,banana-contacts etc.
/Peder ????
Posted on: 10 November 2018 by feeling_zen
Most connections, including regular RCA should be tight enough to allow natural abrasion clean (unplugging/plugging). The clouding seen on many connections of low reactivity metals like gold plate interconnects is usually not oxidization but just accumulated airborn grime. Rubbing alcohol is all thats needed to remove it without residue, but as it accumulates on areas not in direct contact, it's fairly cosmetic. If you want something thinner, a 1:1 ratio of isopropyl alcohol and distilled water is the way to go (also the best solution for cleaning fingerprints of cases and front panels).
Contact cleaner or other mildly corrosive cleaners are, I think, perfectly fine for things not in an signal path. I'd not hesitate to use them on mains plugs for example.
Posted on: 10 November 2018 by Chag...
Huge posted:
I run 5 times in/out series once a year. I am now checking for the closest institution.  :[
Chag -
Posted on: 11 November 2018 by joerand
Huge posted:
"High pressure", "self cleaning", "once each year" and "sufficient"? Really?
Given differences in listener environments and habits, your basis for such an arbitrary statement is what?
Posted on: 11 November 2018 by Huge
joerand posted:
Huge posted:
Yes.  Really.
A degree in chemistry (and having worked in research), an interest in materials science, having done some work as an electronics engineer, the practical experience of having designed, built, tested and optimised audio amplifiers that used DIN connectors and having examined the pins of older DIN connectors after a single removal / insertion cycle.
Posted on: 11 November 2018 by TOBYJUG
I read once that 64 times was the correct amount of in outs.  Taking care especially with the wobbly mains input.
Is that a statistical number?
(Refer to 'Statistics' thread.  )
(Connectors other than DIN may well benefit from more than a single reinsertion cycle.)
Posted on: 11 November 2018 by Jonners
Great thread - my hi-fi and the majority of cables are getting on for 13 years old and I've never once thought about cleaning contacts. Looks like I have a date with a bottle of record cleaner and a microfibre cloth....
Jonners posted:
Don't use record cleaner as it can leave a residue, just use 'pure' isopropyl alcohol.
Huge posted:
A degree in chemistry (and having worked in research), an interest in materials science, having done some work as an electronics engineer and the practical experience of having designed, built, tested and optimised audio amplifiers that used DIN connectors.
Even more interesting! Given your background, your response (below) seems all the more random, arbitrary and pretentious as read by someone with an objective scientific education.
Huge posted:
joerand posted:
Huge posted:
Huge posted:
Well then, do the test yourself: take an old DIN, subject it to a single reinsertion cycle, take it apart and inspect it with a microscope - you may just be surprised at what you see.
Posted on: 11 November 2018 by Suzy Wong
joerand posted:
Huge posted:
Huge posted:
I take it you disagree with Huge. I’m sure we’d all be interested in your thoughts on the subject.
Posted on: 11 November 2018 by Rich 1
That's why before auditioning upgrades, clean your connections because that upgrade might just be the clean connections! Rich
Posted on: 11 November 2018 by Timmo1341
Why on earth can’t some members disagree without being so rude and unpleasant?
Posted on: 11 November 2018 by dave marshall
Timmo1341 posted:
Because it's a forum, and represents a small cross section of society, which, of course, includes rude and unpleasant people.
I find it easiest to simply refrain from responding in print to the more abrasive keyboard warriors who feel that their opinions are all that matter.
Posted on: 11 November 2018 by Simon-in-Suffolk
Yes all contact connections including DIN and RCA benefit from occasional unplug and re-insertion, even if it’s simply to remove the contact oxidisation. With some of the Naim DIN connectors like Hiline, there is also consideration of the physical tensions for optimum conduction so that the pins in the DIN connections are not under undue pressure and tension, that is is you insert the plug then pull out to a degree such that the DIN pins can be seated optimally in the socket connector cups.. usually worth re doing this every few months or once a year. Many quality RCA plugs (like ETI, or WBT such as Naim use) use high pressure contacts and these benefit from being re inserted and clamped every few months..
