Saving To Preset - Naim Unitilite
Posted by: joroma on 10 November 2018
Preset 1 is empty how do I save radio paradise naim to that preset? I have the manual but still can't do it!
Posted on: 10 November 2018 by David Hendon
You can do it in the app. You go to the home page for the streamer, scroll down to the bottom of the list of presets and the bottom one says "edit presets".
So save Paradise in any preset and then use edit to move it to number one.
best
Posted on: 10 November 2018 by joroma
Thanks. I did try that but because preset 1 is empty it isn't available in the edit facility of the app. I can move Paradise up the edit list but only topreset 2. How do I get an entry in preset 1?
I have cleared all the presets using settings menu but cannot store anything using the store button on the remote or the app. Any ideas?
Normally the way you store something using the app is to tune into a station then press the star icon.
Have you tried restarting the Unitilite?
best
