NDX2, pre amp function??
Posted by: Robbert on 13 November 2018
Does the new NDX has a pre amp functie? (which you can use with the remote app)
Posted on: 13 November 2018 by Adam Zielinski
 No.
N272 does
Posted on: 13 November 2018 by cdboy
If you mean will it control your SuperNait2 via the Naim app then yes.
