Scientists are set to change the way the kilogram is defined - without a referendum !!
Posted by: Don Atkinson on 16 November 2018
Scientists are set to change the way the kilogram is defined.
Currently, it is defined by the weight of a platinum-based ingot called "Le Grand K" which is locked away in a safe in Paris.
Researchers are expected to vote to get rid of it in favour of defining a kilogram in terms of an electric current.
The decision is to be made at the General Conference on Weights and Measures, in Paris.
Posted on: 16 November 2018 by Mike-B
It might sound strange to us mere earth bound mortals,  but I understand it there is a changing variation between Le Grand K & its certified copies,  so it makes sense to find another means of ensuring accuracy outside of actual mass (weight).
 The new method will be based on the Planck constant,  & will be defined by fixing the value as the speed of light & the resonant frequency of the caesium atom in a vacuum.
The caesium atom is used in other SI definitions;  the definition of a second is the time it takes a caesium atom to oscillate 9,192,631,770 times.
Earth shattering (not) but if the variation in a kilo equivalent to the weight of 20mm of human hair is important to you  ......
Posted on: 16 November 2018 by Don Atkinson
Hi Mike,
that human hair represents an error of about 50 parts in a billion. Now, if we apply that sort of rough and ready measurement to our gps/satnav systems, we’d be lost !
Indeed Don,   however as much as I trust BA’s navigation systems will get me safely to Cape Town next week,  I suspect the potential of navigational errors caused by this anomaly in Le Grande K will be overcome by the application Mk-II eyeballs & the cleanliness of the cockpit window to ensure we don’t land on the rather large lump of sandstone that someone stuck in the middle of the city.
That's all well and good in the sunshine Mike ! but........
...when the cloud base is 200' and the viz is down to 800m, you don't want to be doing an RNAV approach with the risk of being 50' off the runway centre-line
Enjoy the trip !
PS Mike. Don't worry (I know you won't !). Even in those conditions, most of us would use the good old ILS system and.
..........  and not forgetting the backstop of those Mk-II eyeballs.
Mike-B posted:
Yep, In my case and with our aeroplanes, it's the Mk-I eyeball that sorts out the last ½mile from 200'.
Oh ! and a new "unit" of measurement, at least in my vocabulary is the "light foot". Possibly something to do with Usain Bolt
It's an approximation of course, one foot being the approximate distance that light (and other EM frequencies) travel in one billionth of a second.
Posted on: 16 November 2018 by Christopher_M
I thought I heard something about Ava Gardner's number when this topic was mentioned on the radio yesterday.
Posted on: 16 November 2018 by TOBYJUG
Will this make a difference to the number of Blue whales needed to fill the Empire State Building ?
will the DDBC  - Double Decker Bus Calculator be the same ?
Posted on: 16 November 2018 by Suzy Wong
Don Atkinson posted:
You mean “one foot per nano-second”? Nothing new there for us sparkles........
Posted on: 17 November 2018 by Innocent Bystander
Hi Mike,
If you mean weight per unit length of generic human hair, the variation is considerably more -  it can be at least as much as +/- 60% (assuming consistent density).
Posted on: 17 November 2018 by Don Atkinson
Innocent Bystander posted:
Hi Mike,
Hi IB,
Le Grande K has deteriorated and the copies around the world have also deteriorated. Some of these copies were never precisely accurate in the first place.
The typical magnitude of these deteriorations and variations is represented by the mass of a human eyelash, or 20mm of typical human hair. As you say, human hair can vary in density quite a bit, but these eyelash/hair comparisons give a helpful comparison, at least IMHO.
I have simply extended the comparison to GPS to provide an alternative visualisation of how rough and ready Le Grande K is as a fundamental unit of mass.
TOBYJUG posted:
Not if you stick with the iconic Routemaster..........
Suzy Wong posted:
..... there’s always somebody “light years” ahead of the rest of us ! ........one day we’ll catch up !
Posted on: 20 November 2018 by Don Atkinson
Christopher_M posted:
Hi Chris,
If you're still looking for Ava Gardner's number.................
........you could try + (00) 602 214 0857................
Posted on: 20 November 2018 by TOBYJUG
Meanwhile some other Scientists have been busy with another cubic measure..
https://www.bbc.co.uk/news/world-australia-46258616
TOBYJUG posted:
Holy sh*t !!
Posted on: 20 November 2018 by Christopher_M
Hi Chris,
Good of you Don, I suspect the National Physical Laboratory may have a mole. Thanks for Ava's number but I have a feeling there are a few digits missing, twenty three zeros to be precise.
Hi Chris,
ah! that's what the .......'s were for
As for the mole, I understand that come 20th May next year, that is going to be fixed, once and for all, with dead certainty.
Posted on: 20 November 2018 by thebigfredc
I think there is every chance I am out of my depth here but I thought a kg was the weight of 1 litre of water, hence the specific gravity of water is 1.
Posted on: 20 November 2018 by fatcat
thebigfredc posted:
I’m surprised you know what a kg or litre is. You come across as a CWT and fluid ounce sort of person.
thebigfredc posted:
Ray, you have to keep up with the times. We are leaving the EU. Kg and Litres will be a thing of the past !
Le Grande K is over ! It's much more than a gnat's whisker out of tolerance, it's a whole 3/4 inch of a human hair out !!
And don't rely on us going back to the CWT and fluid ounces business just because JR-M can't get his head around km and Euros.
Take a look in the BBC science section, rather than the "news" compartment !
