naim 250 with nac 272
Posted by: pino on 16 November 2018
Hi everyone
I wanted to ask the friends of the forum this question:
do you think it is right to replace the nac 282 with the most recent nac 272?
my final is nap 250 dr
if possible can you tell me the assembly between the two? (nap 250 with nac 272).
thank you all
Posted on: 16 November 2018 by wenger2015
The Nac 272 is a streamer, if that’s what you are after.
just don’t expect it to be anywhere near the performance of the 282....because it definitely is not.
I would suggest if you are wanting to go down the streaming route try an NDX or NDS...
Posted on: 16 November 2018 by nigelb
Pino, the 272 is a pre amp/streamer in one box, whereas the 282 is just a pre amp, although more capable than the pre amp section in the 272, but with no streamer section.
The 282 also needs a power supply, whereas the 272 does not but benefits if you do add one.
Beat me to it Wenger!
Posted on: 16 November 2018 by Finkfan
I’ve just replaced a 272/555 with a 282/HCDR. The 282 is a far better Pre amp as you’d expect at the price. If it’s fewer boxes you want them the 272 is very good. If it’s a better pre amp you’re after, the 272 isn’t it.
Posted on: 16 November 2018 by HiFiman
The 272 is very capable, no wires between streamer and pre and with the right PSU changes the 272 into a different beast.
Listen and judge for yourself.
Posted on: 16 November 2018 by Numptyhead
Pino
The 272 is a terrific pre-amp all rounder, and if you buy it with the FM/DAB module - you've pretty much got all bases covered. The 250DR is an excellent match (I also used it with a 200 - and it wasn't as good) BUT you really do need an XPSDR as a minimum to heard the 272 at its best. However, as others have pointed out there are better dedicated pre-amps in the NAIM range and the 282 is certainly one of them; but you wont get all the functions and goodies you get in the 272. Best you listen to both pre-amps. Any decent NAIM dealer should be able to do this for you. Enjoy choosing!!
Posted on: 16 November 2018 by Japtimscarlet
The 272 has some nice features like app control and a better volume control than the 282 IMO
I doubt it is a match performance wise to a 282 (though I had to go to 252 to really better the 272)
 If you already have a 282 and want to go to streaming / reduced box count the 272 is a bargain ... especially with the keen prices that are out there at the moment .. both new and used
Posted on: 16 November 2018 by pino
ok thanks again to everyone.
I think I'll listen to both of them at a naim retailer and I'll let you know.
however as a stream I have nd5xs connected to naim ndac.
Posted on: 16 November 2018 by Christopher_M
pino posted:
Is this source of high enough quality for your NAC282?
Posted on: 16 November 2018 by Guinnless
Christopher_M posted:
pino posted:
I should say so.
Posted on: 17 November 2018 by cdboy
Trade the ND5XS and DAC on a NDX2, invest in a 282/HiCap, assuming the 250DR is in place. Add a second HiCap one day. If your (unnamed) speakers are up to it you will hear the differences as you go. Enjoy the journey.
Posted on: 17 November 2018 by Rich 1
Depends on cost (272/250 is expensive, 282/250 + periferals and streamer if required is very, very expensive). Box count and space may also be a consideration. I'm happy with 272 /250 as cost, box count and the law of deminishing returns were a consideration. Would I be happy with a better system? Well yes. Can I at present justify the cost and box count? Only if I win a large lottery sum. My thoughts are, set a realistic budget and listen to all permutations within that budget. Also listen to possible long-term upgrades such as power supply's although that's another box. Rich
