Asset or Bubble to Transcode to WAV?
Posted by: sjt on 19 November 2018
I have Asset UPnP server, and bubble to do the proxying. It seems both can transcode to WAV, so any thoughts on which one is better to do the transcoding? I am controlling a 272 with Linn Kazoo.
I dont know if it makes any difference, but at the moment Asset and Bubble are both on the NAS, but I am going to try moving bubble to a raspberry pi because a) I read on here that it might sound better and b) its a bit of fun to play with the raspberry pi.
Thanks for any advice
Posted on: 19 November 2018 by Simon-in-Suffolk
Transcoding is transcoding... it doesn’t matter what software you use.. as the codecs you are transcoding  are lossless  the transcoding is totally deterministic.
Posted on: 19 November 2018 by Guinnless
I have Asset set to transcode so I can use the Naim app should I wish do so.  However I normally now use Bubble for both Tidal and  local streaming so I could probably turn Asset's transcoding off and let the RasPi do the transcoding.
I don't think it affects SQ either way though.
Posted on: 20 November 2018 by Rich 1
It shouldn't make any difference, but, as you have both why not compare and let us know your thoughts afterwards! Rich
Posted on: 20 November 2018 by Guinnless
Rich 1 posted:
If Bubble already receives a WAV file from asset then Bubble (I don't know if it can detect the MIME type) should either just pass it through unprocessed or re-transcode it to exactly the same file; I suspect the latter.  Either way the ND5XS will just see a WAV file.
I did have a very brief test of a couple of tracks though and nothing jumped out.
Bubble is definitely better than using the Naim App, especially for Tidal.  And as a bonus you can set the track list view and it won't get its knickers in a twist unlike the Naim app.
