So, after my first few encounters with mp3’s (early Napster) I decided to ignore the whole “music from the web” thing, and happily enjoyed my LP’s and CD’s offline. The thing is, the world did not stand still in the meantime and, where I live, it’s getting progressively harder to buy the music I want.
So I was sort of forced to turn to the interweb after all. The things is, a friend who is into streaming showed me that it can sound pretty good too! Long story short: I’ve decided I want in.
So here I am, a complete n00b, asking for advice what to buy.
WHAT I HAVE:
CD-player: CD5 XS
Pre-amp: NAC-122X
Pwr-amp: NAP-150X
Flatcap 2X (for amp & CD)
Phono Pre-amp: STAGELINE (Denon DP-67L turntable)
Speakers: B&W 804 Diamond
WHAT I WANT:
Obviously the best sound possible for my money (I have about € 3000,- to spend (that’s euro’s, not $$, I’m from the Netherlands). Now, most streaming devices I looked in to so far are either integrated with their own amp, or consist of a (rather bewildering) collection of separates. Since I’m still very happy with my Naim kit, integrated solutions are probably not for me. Why pay for an amp I’m not going to use? But please do correct me if I’m wrong. That leaves me with separate “boxes”. And this is where I could use your help.
Before I go any further: any solution will have to with WiFi! I know this sucks, but it’s really not possible to run a cable through my house. So should I stop here and just forget about it, or are there good sounding WiFi solutions you know of? I’ve been reading a few reviews of the Cambridge CXN and I could find only ONE reviewer who used it on Wifi. He was just as enthusiastic as the other reviewers, so that gave me a bit of hope, but I don’t consider a sample size of one solid footing.
Since I can watch Netflix in HD on my PS4 that’s in the same audio rack, I’m assuming the bandwidth is enough for audio streaming. I don’t necessarily need a NAS right away, so if I understood correctly I’ll need a WiFi streaming device and/with a DAC, with an option to hook up a NAS later. Or something like that CXN, whichever is “better”
Sorry for the long read, but I wanted to be as complete as possible. Any help is appreciated.
Thanks in advance
Posted on: 20 November 2018 by What’s in a Naim
Thanks,
This is one of the devices on my shortlist I’m going to try to get demo’d In a few weeks. My main concern is that EVERYBODY, and I do mean EVERYBODY, keeps telling me I really have to hook up a streamer with a cable. Which I can’t. So, although I really love my Naims, my main worry is that I’m buying an expensive piece of kit that will sound just as good/bad as something much cheaper, because it has to work over WiFi.
So, I guess I’m asking if there’s anybody out there that has had experience with WiFi streaming, preferably somebody who hooked it up to a good quality stereo (that’s why I came here
If WiFi is considered so inferior that this isn’t even worth considering, I’d like to hear that too. But I’m hoping that there’s somebody out there who knows of a way to make this work.
Thanks,
That’s the plan. Already found a dealer that sells Naim and Cambridge, among others. I’m fairly certain that my WiFi can support a streamer (Naim or otherwise). What I want to know is: does a WiFi setup automatically sound inferior to a cabled setup, hence making an investment in high quality kit a bit of a waste of money?
I’m sure I can get the stuff demo’d at my house, but I would not be able to hear the difference between cable and WiFi. So while, let’s say, the Naim might sound better than the Cambridge, that still doesn’t tell me if I’m paying way too much for a piece of kit that is perhaps underperforming in my situation.
I hope that I’m clear what my problem/ question is. Feel free to ask if you need more info
Posted on: 20 November 2018 by ChrisSU
The new generation of Naim streamers have much improved WiFi performance compared to their predecessors. They have 802.11ac WiFi modules, where the old models used n or even g modules long after they were considered obsolete by most people. When I first bought my Atom, I used it over WiFi for a few weeks, and it performed without dropouts, although I still decided to instal a cable.
The other consideration is the wireless base station that your streamer has to connect to. If you have a cheap ISP supplied router doing this, there are now plenty of alternatives that can provide a much more robust signal if you need it.
Posted on: 20 November 2018 by Ardbeg10y
This would be my take:
Since you need to use the wifi, try a ChromeCast Audio. It is working nicely over wifi in my place - I have good wifi though so I cannot comment how it behaves in difficult circumstances.
The ChromeCast Audio has one port which doubles for 3.5 jack and optical out. First try it on the 3.5 jack and validate that the wifi is working well. If it does ...
Get a second hand nDac. These are really cheap these days and would suit your current setup very well. It can also be used as an upgrade on your cd player. Get a mini-toslink to toslink optical cable to connect the ChromeCast audio to the nDac.
I live east of Zeist, south of Amersfoort if you need to borrow a chromecast audio, post on my wall it will end up in my mailbox.
You can also go the Raspberry Pi into any dac of preference route, but the RPi has worse wifi reception in my experience compared to a ChromeCast Audio.
Thank you,
that’s really nice of you. And a pretty good suggestion. You’re not the first one to suggest the Chromecast route, so I think I’ll give it a try. Since Chromecasts are not that expensive I might as well buy one. If all else fails I can always hook it up to the stereo in my bedroom.
I still have an old Audio Alchemy DAC lying around, so for testing purposes I’m practically set.
This, together with the suggestion of getting a better router from another forum member, is useful stuff.
Thanks again
