supernait audirvana
Posted by: wildo on 21 November 2018
I just bought a supernait v1, I use a mini mac to place music normally with all my equipment with Audirvana by Digital Optical cable, the problem is that it does not give me the option in audirvana to play by the optical cable superuniti, to someone Has this happened?
Where can I get the supernait v1 manual? is it in Spanish?
Posted on: 21 November 2018 by Richard Dane
The Supernait manual (English) can be found here:
https://www.naimaudio.com/site...l_english_issue5.pdf
Check how the inputs are assigned.  By default AUX 1 (Digital Input 2) is on Toslink Optical, but may well have been reassigned by a previous owner.
If you wish to reset the Supernait to default settings, turn it off, wait 2 minutes, turn it on again, wait 1 minute until everything stabilizes. Now with the remote control, press and release the "Pre" key, press and hold the "Prog" key until the volume control's light starts blinking, and then press and hold the "Disp" key until the Supernait resets itself. The procedure is completed when the volume control's light is steady, and no buttons on the two rows are blinking.
