Muso App
Posted by: fatcat on 22 November 2018
I’m considering buying a Muso QB. From what I can gather, I won’t be able to load the Naim app onto my Windows phone. I have an android phone that is about 4 years old, with an old version of android. I seem to recall my fitbit watch will only work with newer version of android. Is there a list of android version that are compatable with the naim app.
Also, will the Muso stream BBC iplayer.
Posted on: 22 November 2018 by Guinnless
You could try the Naim App on the Android phone and see if it installs ok. I'd be surprised if it didn't work.
The Muso won't stream iPlayer but will play some "on demand" and radio podcasts.
Posted on: 22 November 2018 by ChrisSU
You need Android 5.0 or later to run the current version of the Naim app.
The Muso has AirPlay, so will stream iPlayer from iOS. On Android, you should be able to do this with a third party app such as AirStream.
Posted on: 22 November 2018 by fatcat
Thanks.
My old phone has Android 2.2.1, so that's no good.
However, my wife has a samsung SM T280 tablet with 5.1. So. could permanently borrow that.
