Are a Naim XPS2 and a 555PS viable for use with a CD555, compared to a dual 555PS.
Posted by: vintageaxeman on 25 November 2018
I have read about how two 555PS power supplies are better than one with a CD555.
I HAVE a CD555 and one 555PS. I was wondering whether it is possible to use an XPS2 plus a 555PS together to power the two separate sides (digital and analogue) of the CD555. Anyone please? Thanks, folk.
Posted on: 25 November 2018 by hungryhalibut
No, it won’t work.
Posted on: 25 November 2018 by Richard Dane
Only the 555PS (one or two) should be used to power the CD555.
Posted on: 25 November 2018 by andrew jameson
Curious about your active  ATCs ... how are you finding them? I'm currently contemplating a of SCM50 asl
Posted on: 25 November 2018 by douglas
CD555 with one power supply. Brilliant. Even better with two. Both DR! Must be 555PS and no other.
Gives my Stiletto Linn LP12 a close run thing.
Douglas.
Posted on: 25 November 2018 by vintageaxeman
Thank you guys. My question is answered! Cheers!
andrew jameson posted:
They are very clear and revealing. Probably my room would have been better with 50s or 100s, but I only had the opportunity to get these 150s, so I was stuck with that choice. In fact I have some fab passive Celef speakers elsewhere in the house which use the same 9½” bass units that are used in the 50s, and they used to fill a 20’ square room with sound. But beggars can’t be choosers, and I AM a beggar, plus I’ve never shrunk away from BIG systems. Never WAS a shrinking violet. ???? Always believed that good bass requires plenty of air shifting, and being a bass guitarist, good tight but thunderous bass, (when it needs to be) is very important to me. Physics is physics is physics.
Posted on: 26 November 2018 by MDS
As others have said, it's only one or two 555PS on the CD555. No other PSUs.  If you were tempted to get a second 555PS, do try at home before you buy.  I recently had a second 555PSDR on demo for a week at the end of which I concluded I preferred the CD555 with just the one PSU.
Posted on: 26 November 2018 by andrew jameson
vintageaxeman posted:
Thanks! I'm demming the 50s next week - my room is 6.5x5.5m so whilst i'd love the 150s i suspect they'd be overdoing things!
Posted on: 26 November 2018 by ameden
Listened to the SCM50 Actives last week....absolutely awesome....I think you need circa 30M2 - 50M2 room size for them to breathe....which you have...
To 'big' for my room (unfortunately)...I have a home demo of the SCM40 Actives later this week...
Good luck
