No multiroom via airplay2 with nd5xs2?
Posted by: Andib on 29 November 2018
Hi all,
I kindly ask for some support.
I tried to connect 3 components to a multiroom system:
muso, muso qb, nd5xs2
The musos play together, the nd5xs2 only plays alone. Is it not able to do multiroom via airplay2 with it? It has the latest update.
Thank you,
Andreas
Posted on: 29 November 2018 by hungryhalibut
The ND5XS does not yet have Airplay 2. It is currently being tested, so hopefully won’t be too long.
Posted on: 29 November 2018 by Andib
Thank for answering. You ment the new nd5xs2?
If yes, will it perhaps be enabled with an update?
Yes, sorry, the XS2. There will be new firmware in due course.
